Does anyone know about how much horsepower a 2110 makes. Here are some of the comp. I have not got this motor in yet is being put in as we speak and I'm not sure what to expect.
82mm Scat Pro Crank
044 Heads
44 Webers
Merdged Header
Get your self a copy of desktop dyno, you can screw around in there, but I don't know how accurate it is. I think I read somewhere it over estimates by like 5-10 hp.
Desktop Dyno is fun to mess with, but it gives you hp figures assuming you are in an optimal environment. It tends to over rate hp and torque figures by roughly 15-20%
With a mild cam (engle 120) and a compression ratio at about 8:1. that combination will probably make 140 HP maybe a bit higher. Don't be too concerned about HP ratings or guesstimates though. The big factor is how much low end grunt (torque) it will produce. That's what will put a smile on your face.
