250HP+ 1600DP Mouse Motor
Re: 250HP 1600dp
Off Topic
- ToRy 70
Re: 250HP 1600dp
I think 1641 should count.Clonebug wrote:So at at 102 cu I am out.........Off Topic
1641 cubic centimeters =
100.14 cubic inches
Sent from my LG-H932 using Tapatalk
- buguy
Re: 250HP 1600dp
He is 1679 I believe. 102.45ci
- Wally
Re: 250HP 1600dp
So what would you call 1200 cc’s then?
- Kalle
Re: 250HP 1600dp
Hi Mario,
How is it going with your mouse engine?
Best rgs
Kalle
- MarioVelotta
Re: 250HP 1600dp
Well, I kinda got sidetracked with a supercharger on my stock 1600. I seemed like a good idea since everyone else has one
Since then I've pulled the motor to have my transmission serviced. It's back I just have not reinstalled it. Once I do that I can get some SC dyno numbers, I'm really interested in the torque as it's making 9psi at 2000rpms. It's like driving a small 2L
After I get the dyno numbers I can finish assembly of my turbo 1600. I needed to have the case re-machined as 3 of the bearings were too tight and make a final decision on the cam to use with my Los Panchitos.
I've got a good assortment of cams to choose from but I' think it needs to be pretty aggressive to keep up with the custom cam Chip got from Paradise.
[email protected]
[email protected]
- Chip Birks
Re: 250HP 1600dp
Bahahaha! You've got much better heads and are much better behind the laptop than me! I don't think my little VWP cam is gonna make all the difference! E85 might help me though, just a little.MarioVelotta wrote: ↑Mon May 14, 2018 8:38 amI've got a good assortment of cams to choose from but I' think it needs to be pretty aggressive to keep up with the custom cam Chip got from Paradise.
- Kalle
Re: 250HP 1600dp
Perhaps not useful info at all but I ran a very mild cam on my 1641ccm engine. Basically a W110 on 112 lobes by JPM which again allowed me to use 1.5 rockers. Not a lot of lift even with the 1.5`s. Changed the CB650 springs every second year/season even though I was not forced to since they did not loose a lot of tension.
Best rgs
Kalle
Best rgs
Kalle
- buguy
Re: 250HP 1600dp
Do you have any numbers or timeslips with that engine?
- Wally
Re: 250HP 1600dp
I think all data and info are further back in this thread. Kalle shared everything afair
T4T: 2,4ltr Type 4 Turbo engine, 10.58 1/4 mi
www.apfelbeck.nl
www.apfelbeck.nl
- Chip Birks
Re: 250HP 1600dp
Thats crazy! Mine isn't crazy wild, definitely bigger than a w110 though! Just goes to show, an efficient turbo and good fuel make all the difference.Kalle wrote: ↑Tue May 15, 2018 6:28 am Perhaps not useful info at all but I ran a very mild cam on my 1641ccm engine. Basically a W110 on 112 lobes by JPM which again allowed me to use 1.5 rockers. Not a lot of lift even with the 1.5`s. Changed the CB650 springs every second year/season even though I was not forced to since they did not loose a lot of tension.
Best rgs
Kalle
- Kalle
Re: 250HP 1600dp
Hi buguy,
Here you go:
- 1641ccm
- Mahle barrels and pistons.
- Scat 5.5 rods with Scat 625 rod bolts.
- Home ported CB044 heads with 650 springs.
- DPR 69mm crank.
- JPM version of a W110 cam.
- JPM Alu pushrods.
- Precision 5862 turbo with a T4 flange AR58.
- Custom exhaust and intake system using a PWR water to air intercooler and manifolds from vwspeedshop UK.
- E85 with a Aeromotive Eliminator in-tank fuel pump.
375 whp at 26psi and a fair bit above 400whp at 35 psi and 10.41/137mph in a heavy 67 but more importantly: really reliable with minimum maintenance and PLENTY of fun! Fully streetable and only minor issue was to get high enough oil temperature. It looks like this:
And Chip, I agree! Feel free to use a high lift and aggresive cam but you will have to leave with that choice afterwards and adapt to it with frequent valve spring checks and higher spring pressure - more wear and tear.
-K-
