Why on earth turn the boost down with big heads? Crank it up even higher now that the thing can breathe!
Safari Turbo/Megasquirt Fuel Injection Project
- Chip Birks
Re: Safari Turbo/Megasquirt Fuel Injection Project
Turn the boost down?
That's crazy talk.
That's crazy talk.
- petew
People have been kicked off the forum for less heinous crimes...
The point I was tryin to make is You don't need to crank up the boost with these big stroker motor's to make the same if not more Power/torque
15 lbs of boost ain't the same with a 1585-1676cc compared to a 1915 or 2276cc wish I lived closer to u guys I'd let u drive my Bug It will make u swallow your gum
- petew
I'll take you up on that offer in August!
I'll have it all fueled up for ya ,don't forget your 'Gummihosen' you may need them
- Chip Birks
Its very true, mine made 201hp at 7psi, and 236hp at 9. Both on a very conservative pump gas tune. It wasn't happening at 3000 rpm though, more like 5000-6000. Doesn't mean I don't enjoy 20+, and I'm still gonna push this thing to 30 or so.
A longer stroke (AKA "a long throw" [an old hot rodder term]) with a properly ground high lift, short(er) duration cam (a bigger bore also helps) is going to give you a lot of low RPM grunt but the high end RPMs aren't going to be there because of the cam grind. A big stroke is also going to require some case mods too.
He who must not be named
Got a little bored the other day so I whipped up a cover for the back of the intercooler to pretty it up a bit.
I also redid the sticker since I blocked the old one....don't want to be accused of not warning the challengers.......
Might be heading to Mario for a ECU upgrade next week. I'll get my fan to operate off the ECU instead of the Hobbs. That way I can program when and how long I want the fan to stay on instead of it only being on when over 4 lbs boost.
I'll also be making an order for the clutch and pressure plate by the first of the year and possibly a new WI pump too.
- buguy
I love it! My boss bought his son a huge vinyl printer a year ago. I don't think he has it quite figured out but he's been making some stickers. I need to have him start making us some!
- buguy
I don't have anything on mine. I need something fun on it!
You can copy mine If you'd like?
That one made me smile
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Porsche piston squirters
30mm triple "O"ring pump
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
SL-1 Turbo prepped heads
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
Ya that one is hilariousmadmike wrote:You can copy mine If you'd like?
Sent from my SM-J727T using Tapatalk
Turbo!
