Single point injection carb replacement
- Paul H
Re: Single point injection carb replacement
Yes they are selling
Here
If you are in USA then contact me first as the shipping calc in the store is way high and VAT is deducted
Should have a turbo attachment with secondary injector and dump valve built in real soon
Here
Real parts=Real Performance-Get Real
Opinion is the medium between knowledge and ignorance (Plato).
Thanks Paul. Does the TB have provisions for MAP sensor?
Lanner
Lanner
- Paul H
You just use the port on the OEM manifold or there is a boss on the TB you can drill/tap to 1/8th npt and use an adapter
- Wally
Very nice new development Paul!
T4T: 2,4ltr Type 4 Turbo engine, 10.58 1/4 mi
www.apfelbeck.nl
www.apfelbeck.nl
- Paul H
Thanks
Here's a couple of pics of the plenum with extra injector and dump valve which I won't be able to supply -cheaper to make your own but you can
see how it can be done.
I had the stainless turbo headers modified so they accept the cheap "ting tong" turbos
I take it you use the DTA ECU to run that single injector setup.
Does Megasquirt have the ability to do that????
std and extra ms 1/2/3 yes, its just a TBI setup, supported since ~dirt.
microsquirt needs high z injectors or external driver for low z.
Typically TBI injectors are lowZ, but I'm not sure what he's using...
Its possible some of the newer TBI injectors are high Z.
TBI is easy to do, but never suggested for highly tuned engines for the exact same reasons centermount carbs are never recommended: fuel fall out and uneven fuel distribution.
(basically huge AFR differences hole to hole)
- Paul H
You can use any ECU to run that system and high z injectors upto 80lb/hr (140hp each) are readily available.I've changed down to a 60 lb/hr as maximum hp through the end castings is 100hp/5000rpm so that would be 1776/1904cc, engle 100/110, stockish heads.Anymore than this just fit ITB's but bear in mind that tuning smaller engines with heads and cams up into the 130hp and above 5000rpm is pretty pointless as the stock fan setup will rob your power almost as fast as you can make it
- Wally
As seen when engines on dyno also do a run without the belt on.
Its still pretty funny to express it like that me thinks, but Paul is notorious to tell it the way it is...
Still, my own recent development of the 2,2 turbo engine made max.hp at a real 7300 RPM. It was the higest max RPM at max hp reading at that dyno to date
- Paul H
Yes fan belt hp loss needs to measured across the whole rpm range and not just quoted as a +/- number at peak power.
If you have a 300hp turbo motor then a 25hp loss is no big deal but on a smaller NA motor then it is a substantial loss
- Wally
That was my new engine, but dyno'd in N/A mode with fan belt on. It was even the horizontal (Porsche style) fan set-up with 90 degree belt arrangement
Only made 189 hp at 7300 RPM, but its low compression to be turbo'd later this year.
I agree though, fan belt loss is an absolute number per set-up and progressively higher with rising RPM.
The Corvair racers used several tricks to counter the fan losses...
One setup added a disk under the pulley that restricted the air intake at high RPM, but had little effect at low RPM.
Second, they sprayed the belt with silicone lube so it world slip far more at high RPMs.
Yet another setup used an AC compressor clutch on the crank pulley.
- Paul H
The VW T1 cooling was designed for 5k max which is clear as day once you do dyno tests so best to keep it there and build an engine that works best up to that limit above that use a smaller crank pulley.I think Porsche cooling is slightly more efficient but I never tested that system
How well would this work with boost on a single injector?
Thinking stock inlet manifold, this TB and a TD04 on a 1915cc.
Fired an email off to Paul too just incase hes not lurking on the forums currently.
- Paul H
I got the email and replied-maybe spammed
I haven't ran a turbo through it but no reason why it won't work.
Make sure you can get a single injector big enough or use a secondary injector
upstream.
Largest single high resistance injectors I use are good for max 140 hp
There is a pic on this thread of a quick mock up I did using off the shelf bits with a second injector.
upstream.
