Shock Setup
Re: Shock Setup
Norm, from floor to roof is 42". Did you built your front shock mounts? Of are that an kit?
Re: Shock Setup
J, you could either rename this string or start a new build string.
If you notice on Norm's rail the shock towers of the beam are not part of the beam. Those AL beams with shock towers have a tendency for the shock tower to not flex a lot and crack/fail. At the least I would put a spreader bar between the two shock towers to take up some of the loading.
Norm was also talking about the tie-rods hitting the frame. If your not going with mass travel then a R&P box using end links are a way I have seen it done. I'm not sure how they do it but front steering racks are getting more common to see.
A hoop behind the seats is a good idea but it also can make access to the rear seats a bit awkward (see tree guards below). It would also make the harnesses attach more correctly; they way they are attached right now is not the best way. There is a hoop there mounted to the rear hoop but it depends on how the connectons between the front pillar, the rear pillar and the hoop off the rear hoop are attached to each other but putting in the second hoop I think would be a safer option.
I can't tell where you are from or ride but if there are trees around where you ride then tree guards would be a good idea. They also are good in tight places to keep the tires from hitting and hurting the rear suspension (from experience). One of the advantages here is you could put a floor (diamond plate AL?) on the tree guard so you can not only use it as a step, especially for the back seat entrance, but it helps to keep rock and other debris thrown up by the tires away from people riding inside of your buggy. I see them more and more where I ride.
If you ride on rocky trails then rock sliders might be a good idea to put under the frame. If you have an expanded metal floor and are not riding in the sand or in sand where tree branches or other stuff such as rock/gravel that could come up through the floors then I would look into converting over to a solid floor if you don't have it already. Expanded metal on the floor is still in use on the sand.
Just some thoughts
Corrected to show picture
Just some thoughts
Re: Shock Setup
Norm, floor to foor is 42". Did you fab your front shock mounts or did you buy a kit?
- Sandbar Norm
Re: Shock Setup
Hi JRam, Mine is 34" to 36" floor to roof.
I fab the shock hoops myself when I rebuilt the front end. It looks like I am going to get to do it again. This time I don't think I'm going to do the hoops. I'm going to triangle straight tubing to fab the upper shock boss.
I will start a build form when it goes under the knife. Just not much to show yet and still asking some question as I'm not sure of which way the build be.
Back to the original forum. For rear shocks, I'm looking at FOX 2-1/2" dia. maybe 16" long. We will see ($$$).
Norm
Norm
- dustymojave
Re: Shock Setup
16" is a hell of a big shock on a swing axle that gets at MAX 9" at the wheel. Are you thinking of converting to IRS like on the Raceco 1600 race buggy that you used for an example?
Richard
Lake LA, Mojave Desert, SoCal
Retired Fabricator
Retired Fabricator
- dustymojave
Re: Shock Setup
One basic in setting up shock mounts is to "cycle" the suspension before placing the mounts to ensure that the setup works.
Another basic is that the shock mount bolts should be parallel to the pivots for the suspension. With swing axle, that means the shock mount bolts should be at 45° to the centerline of the frame of the car, with IRS the bolts should be parallel to the IRS pivot bolts.
Yet another is that the shock travel length should match where the shock is mounted.
- A 6" travel shock mounted near the wheel with 9" of suspension travel will not work. The shock will limit the travel.
- But a 16" travel shock where the suspension can only travel 9" is not good either.
- A short travel shock mounted up the arm like the forward shocks on that Raceco works. The forward shocks on that car are probably 8" travel and the rears 12". That suspension setup probably made 12" of travel as it sits in the picture.
Richard
Retired Fabricator
Retired Fabricator
- Sandbar Norm
Re: Shock Setup
Hello dusty.dustymojave wrote: ↑Sun Nov 19, 2017 11:31 pm 16" is a hell of a big shock on a swing axle that gets at MAX 9" at the wheel. Are you thinking of converting to IRS like on the Raceco 1600 race buggy that you used for an example?
If you are talking to me, I now have a T1 trans with stock IRS. I plan on putting in a 5 rib with 3x3's with a disk brake upgrade. I have all the major parts besides the brake lines, bolts and other stuff. Also going to try a air bag setup.
You are right about the shock length being long. I will measure before buying.
Re: Shock Setup
Not sure right now Dusty. I might just pull everything off this Frame and get exactly what I want, kind of like the example that I have
Re: Shock Setup
Check where the shock mounts are located on the 3 X 3 arms (if they have them) as they could be located in the stock location.
