Trailing arms
- itawolf
Trailing arms
Lots of iron in the fire
Re: Trailing arms
I get a message saying that the video does not exist.itawolf wrote: ↑Thu Jul 13, 2017 10:55 am What is this about??
T arms??
HTTPS://www.youtube.com/watch?v=2FaFRTMWIo
- itawolf
Re: Trailing arms
Re: Trailing arms
Interesting but I don't know what he is saying. The Freio, is it a VW Rabbit? There are some things I am not completely sure of but it is interesting to say the least.
- itawolf
Re: Trailing arms
I speak Italian but I think Freio is "brake" in Portuguese
That's an interesting setup for sure
Something of disk knife adjustable??
Re: Trailing arms
One of the things I saw that I would be leery of was the double Zee shaped tie-rods. Not fond of bends in tie-rods especially where there are going to be a lot of loads applied including banging on the tires and wheels.
Not sure about the tube style trailing arms in the rear either. To be honest I am more involved in rougher usage than I think this design is for. It might be OK for street only but other than that...
- Marc
Re: Trailing arms
"Fusca" is Portuguese for Beetle. Google Translate returns the same result in Spanish or Portuguese, "Chassis of Beetle with IRS Suspension Disc brake Ratchet and Adjustable Frame".
Bumpsteer looks atrocious on that rack, but it probably is OK once some weight is on the pan.
- itawolf
Re: Trailing arms
I believe that may be parts from the Brazilian made dkm/vw PUMA GT and or superbeetle
just have never seen the rear trailing arm setup
not crazy about front thou
- Marc
Re: Trailing arms
Presumably the offsets in the tierods are needed to provide clearance at/near full steering lock; they look like OEM parts - should be more than adequate for most usage (a lot of old Detroit iron had much scarier-looking bends in their steering linkage, on far heavier cars).Ol'fogasaurus wrote: ↑Thu Jul 13, 2017 8:35 pm One of the things I saw that I would be leery of was the double Zee shaped tie-rods. Not fond of bends in tie-rods especially where there are going to be a lot of loads applied including banging on the tires and wheels.
What shocked me was the huge sections lopped out of the frame horns (way more than needed for CV/axle clearance). Would have to see how they braced them on the underside to know, but the flat-stock that's visible doesn't look like it'd resist bending very well.
- itawolf
Re: Trailing arms
- itawolf
Re: Trailing arms
Dang still can't post a pic
Really like to know more about it
Yet I don't think my yapping will go over well
Seems they are vw bus trailing arms
