First time turbo build
Re: First time turbo build
Got the kafer bar installed and finally put the engine back in. I can't wait to habe this car running: D
Added some goodies to the ecu to run the idle pwm.
- buguy
I really like the way you attacked this.
- buguy
Yeah but you were smart and methodical. No wasted motion! I think you would have made a good engineer (if your not!)
Finally got a chance to get back into the bug. Got my header in and oil cooler and started wiring the relay
Got a chance to take the family to the city while they were visiting
Now that my free time is back it's time to get this bad boy runningYou do not have the required permissions to view the files attached to this post.
I'm kind of confused on where the black wire for the fuel pump goes. Based on Mario's wiring diagram for the relay board it says to install with the engine ground. So does that mean the spot on the board along with the main ground or tired into the ground that will be attached to the board? Electronics are not my strong suit haha
If I remember correctly I have the relay board supplying the power through the on-board relay output.
I have my pump grounded to the pan right by the pump on the pan so power would have to come from the Relay Board.
So far that's how i have it. Relay board providing power and i guess i can ground to chassis. I wasn't sure if i had to ground to the engine ground hole on the upper right side of the relay board.
I've been following Mario's guide.
http://www.thedubshop.net/fuel-injection-install-tech
I have a buggy so I just grounded it to the bolt that holds my horn bracket to the pan. It's just a few inches away from the fuel pump.
Got some more work done on the wiring and engine.
Harness all covered up. Also started the piping for the oil pressure sender, temp sender and turbo oil feed. Going to have a 1/4" line made. Would that be too large of a line or should a get a 3/16 line with 1/4 ends?
I use Stainless Steel Flex Brake lines 3/16"
- Chip Birks
I just use 1/4" steel braid. I have a restrictor right after it. Low mounted turbo, zero oil issues.
- buguy
