2,4 type4 turbo 500hp -on gasoline- goal
- Wally
Re: 2,23 ltr type 4 turbo build-up
Fitted most things, now need to trial fit inside, so one last pic outside the car:
T4T: 2,4ltr Type 4 Turbo engine, 10.58 1/4 mi
www.apfelbeck.nl
www.apfelbeck.nl
- petew
That is 18 kinds of awesome.
- Wally
Cheers Pete!
I also managed to fit the type 1 exhaust after some fittling..
www.apfelbeck.nl
www.apfelbeck.nl
Beautiful Wally!!!!!
- Wally
Cheers!
Even more happy was I with today's package that arrived:
www.apfelbeck.nl
www.apfelbeck.nl
- Kalle
That big box for such a small turbo....
It comes flat packed from Ikea
- Kalle
- Wally
Fysical size doesn't probably tell the whole story here
www.apfelbeck.nl
www.apfelbeck.nl
- panel
What is the electronic actuator for ?
- Wally
Its an 'intergrated' Boost Control Valve. You can also see the intergrated BOV and on the bottom (not really visable) is a pickup point for a shaft speed sensor . All these items are a standard part of these turbo's: EFR: Engineered For Racing
The turbine wheel is made from Ti-alumid alloy and half the weight of an inconel wheel as seen on other turbo's like a GTX, whatever Gen they are
Plus of course the forged billet alu compressor wheel with 65 lbs flow capacity and the duel row ceramic ball bearing cardridge and the stainless steel twin scroll housing with V-band.
You can tel I like these. A lot
www.apfelbeck.nl
www.apfelbeck.nl
I have wondered if the greased (sealed) ceramic bearing turbos might work on an ACVW---
no oil flow, need the lower EGT of a long tube setup, but can be mounted any orientation.
Just musing, slick setup, as expected.
- Wally
These turbo's do use an oil feed (and return obviously) however, same as any other turbo.Piledriver wrote: ↑Fri Mar 03, 2017 2:28 am I have wondered if the greased (sealed) ceramic bearing turbos might work on an ACVW---
no oil flow, ..
