What method do you guys use to pull degree pulleys inside the car? Can find a puller that fits. Santana style Scat pulley. Just put it on and its interfering with the tin/oil pump stud; so I can't just bend the sheetmetal out of the way.
Ideas?
Pulling Degree Pulley?
- Marc
Re: Pulling Degree Pulley?
I've never encountered an aluminum pulley which fit so snugly that it couldn't just be wriggled off...you may need to pry it gently away from the case on one side while tugging on the other until it starts to come free.
I suppose a heat gun would help if it won't budge cold...
- Leatherneck
IF it is on and interfering with the sheet metal seems you'll have to remove said sheet metal to pull it as Marc said.
Hmmm... I wonder, Al and steel are dissimilar materials assuming it isn't just the access through the tin that the oroblem.
- sideshow
Normally aluminum ones are super easy to remove as they crack at the key way, you could wait for that to happen.
Now if you are in a hurry, why not the common (stock ones will not work as they are two-jaw-ish) aftermarket puller?
http://www2.cip1.com/ProductDetails.asp ... C-C10-7013
- Marc
Actually I've rarely encountered problems with cracking on the "5-hole" aluminum pulleys, regardless of manufacturer...in my experience it's been the 4-slot ones that self-destruct, I theorize that it's a harmonic vibration thang.
It's a new scat pulley. They say in the directions to pull it form the center somehow, and not where the belt goes. If i had ran the oil pump studs in another 2.5 turns when i put the engine together it would'n't be an issue lol.
