Urabus...it's in the works (Subaru EJ20T build)
panel
Contact:
Re: Urabus...it's in the works
Post by panel » Sun Nov 03, 2013 2:01 am
Not really an update here but more like a poll. I have to buy some silicone hose for some intercooling, turbo and related intake stuff. Should I go blue or black. I'm on the fence. I want some bling(blue) but I kinda want the clean black factory look also.
Subaru JDM EJ20 Turbo bus
Master slacker
Post by Master slacker » Sun Nov 03, 2013 2:33 pm
Always bet on black. It's subtle and the blue looks like a "tuner" to me and not in a good way. YMMV
billz60vw
Post by billz60vw » Mon Nov 04, 2013 3:17 pm
I vote black! Blue looks like ass when dirty.
panel
Contact:
Post by panel » Sat Nov 09, 2013 5:53 pm
Black it is then.
Also:
Here's a bit of the workings of my radiator cooling system. First is the OEM plastic end tanks. Bulky and ugly for sure.
Here's the overview with it all mocked up etc.Rubber hose in there for affect.
Fan switch. I'll be running a stand alone with dual fans. This one is a 10" and another 10" on the way.
5/16" return line to the tank on the intake
Here is the aluminum end tanks at a closer look. They were rectangular before this but just cut in half.
panel
Contact:
Post by panel » Sun Nov 24, 2013 5:40 pm
Not much to report other than getting something in from USPS from http://www.siliconeintakes.com
Got a reducer at the turbo end and 2 x 90 deg for the TB and intercooler to connect. I also got my other fan and nice 'T' bolt clamps.
panel
Contact:
Post by panel » Sun Mar 02, 2014 6:26 pm
Little update........ see below the progress.
Got the flex plate off and the adapter plate on,flywheel and back on the stand.
Had a nice aluminum sheet metal plate made up from my Dad to hold all the little boost components.
And also working on the heim joint adjuster for the alternator.
panel
Contact:
Post by panel » Sun Jun 15, 2014 10:30 pm
Got a few things done this past few weeks. I just have to weld the inspection panel in but the hole is cut and the bottom side is painted/colour matched etc. Looks pretty good if I do say so myself, almost looks OEM. I also got one motor mount done.
Prtexx
Post by Prtexx » Mon Jun 16, 2014 8:25 am
Looking good, on the road this summer?
Steve
67 VW roadster
36 Buick 3 window coupe blown 350
87 Syncro 2.5 Subaru
84 Westy
77 Westy 2.5 5 speed
FB VW Subaru Conversions
panel
Contact:
Post by panel » Mon Jun 16, 2014 10:05 pm
Prtexx wrote:Looking good, on the road this summer?
Probably not, I'm slow :cry: I used to be quick at this stuff but a 4yr old little girl keeps pulling at me to go on the trampoline all the time :lol:
panel
Contact:
Post by panel » Tue Jul 22, 2014 10:35 pm
Shoe horned her there today for a mockup..............
RonW
Post by RonW » Tue Jul 22, 2014 11:15 pm
outstanding panel. looking forward to seen next steps!
912R + STi 2.0 Turbo JDM v8
panel
Contact:
Post by panel » Wed Aug 27, 2014 12:50 am
Had a chance to finish off the motor mount. I'll post some pics of it installed next. I was able to incorporate most of my old 'kafer bar' style mount that I used before using heim joints.
I used a tie rod to link the two mounts
Passenger's side(below)
Left/drivers side....
panel
Contact:
Post by panel » Tue Sep 02, 2014 8:51 am
Had the ball rolling again and got a little exhaust work done.
Also got the pulley made less the grooves for the A/C and power steering and got my alternator adjuster back from my Dad
And then just a general top view of work in progress
panel
Contact:
Post by panel » Thu Sep 11, 2014 8:40 am
Got the primaries finished on the weekend.The flange for the turbo just has to sit on the top of that pipe.....tack it , then I can start running the exhaust from the turbo snake it through everything else all the way to the muffler.
You can also just make out the motor mount in the background of some of the pics.
danielzink
Contact:
Post by danielzink » Thu Sep 11, 2014 8:22 pm
Love the single pulley.....just tonight I was google'ing "single subaru pulley".
I'm putting an EJ22 into my sandrail I have no use for the extra wide pulley.....just need to run the alternator....
Also digging the alternator adjuster....tell your dad you know someone who wants another one <LOL>
nice stuff though...good work !
Dan
65 Notch 2300cc Type4
EJ22 powered Rail
http://www.danielzink.com
