Exhaust system.
58sleeper
Exhaust system.
Post by 58sleeper »
I'm thinking of buying this exhaust for my stock type 4 engine.. Does anyone know what kind of headers go on this?
http://store.vintagespeed.com.tw/index. ... &Itemid=80
-58
58sleeper
Re: Exhaust system.
Post by 58sleeper »
I'm looking at Headers and it says CU or CJ engine. Does anyone know what these letters are referring to?
Munchhausen
Re: Exhaust system.
Post by Munchhausen »
These letters are the engine-code. CU and CJ are 2Liter engines from the vanagon.
munch
supaninja
Re: Exhaust system.
Post by supaninja »
their heater boxes have the same flange to the muffler as the 72-74 bus/411 and 412's did.
viewtopic.php?f=14&t=140387
58sleeper
Re: Exhaust system.
Post by 58sleeper »
So, why do this company sell a CJ and a CU model of the same headers?
http://www.crengineering.de/shop/catalo ... Path=70_88
-58Sleeper
58sleeper
Re: Exhaust system.
Post by 58sleeper »
Plus, I'm not finding CU and CJ engine codes.
Volkswagen Type 2
Code: Year: Engine:
Numerals 1961-1963 1200 (see Type 1 listings)
O 1964 1500 (no cam bearings)
H 1965 1500
HO 1966-1967 1500 (no crossmember holes)
B5 1968-1969 1600 (single relief)
AE 1971 1600 (with crossmember holes)
CB 1972-1973 1700 (dual carb, manual trans)
CD 1973 1700 (dual carb, auto trans)
AW 1973-1974 1800 (dual carb)
AW 1975 1800 (fuel-injected)
ED 1975 2000
GD 1976-1979 2000 ('79 has Vanagon heads)
GE 1979 2000 (California only, Vanagon heads)
CV 1980-1983 2000 (Vanagon -- unique case and heads)
Volkswagen Type 4
Code: Year: Engine:
W 1971 1700
EA 1972-1974 1700
EB 1973 1700 (California only)
EC 1974 1700
Porsche 914
Code: Year: Engine:
W 1970-1971 1700 (8.2:1 compression, D-Jetronic)
EA 1972-1973 1700
EB 1973 1700 (7.3:1 compression)
EC 1974 1800 (CA-only, 7.3:1 comp, L-Jetronic)
AN 1800 (8.6:1 comp, D-Jetronic)
GA 1973-1974 2000 (7.6:1 comp, 3 intake studs)
GB 2000 (8.0:1 comp)
VO 1700 (Euro-only, magnesium)
1800 (Euro-only, magnesium)
2000 (Euro-only, magnesium)
58sleeper
Re: Exhaust system.
Post by 58sleeper »
Got it..
CJ'76-'79 VW Transporterno information70hpEuropean market, solid lifter. dual carb,
CU1980-83 VW Vanagonno information70hpenclosed breather tower. Identical to the CV case, but used dual 34PDSIT carbs.
supaninja
Re: Exhaust system.
Post by supaninja »
My guess is the CJ are the oval flanges and the CU are the square flanges. On the stock exhaust the late buses had a y-pipe as the heater box, maybe the CJ's used a different exhaust style then the US spec'd buses. I know the vanagons had square port heads but used a seperate pipe style like the earlier type 4's. I also noticed in the pics from that link, that they used the same photo for the fancy equal length one.
wildthings
Re: Exhaust system.
Post by wildthings »
They use the same pictures for both, showing flanges for oval port heads. Sounds like a call to the supplier or manufacturer is in order.
64 sunroof
Re: Exhaust system.
Post by 64 sunroof »
In Europe we had the 72-74 style heat exchanger and exhaust right till the end of the type 4 in 82. the only difference between <78 and >78 is the square ports on the head and therefore the heat exchanger.
worth noting that the CJ engine for the bay in 79 came with square port heads
hope that helps
58sleeper
Re: Exhaust system.
Post by 58sleeper »
64sunroof and all of you guys.. Thank you for the information...
-58Sleeper
58sleeper
Re: Exhaust system.
Post by 58sleeper »
I wonder which code would be like GA/GB?
Ove
Re: Exhaust system.
Post by Ove »
I'm bumping this thread - I also wonder
what type of headers fit on GB (100 hp) engine.
Will CJ or CU fit ?
Rgds
Ove
English Lad
Re: Exhaust system.
Post by English Lad »
I used one of their bus super flow muffler's for my 79 bay running mild 2ltr. My application was bolted upto the heat exchangers, no problem with fit and is a higher than expected quality.No loss of power and much quieter than other so called performance exhausts.What exhaust system are you now running?Do you use heat exchangers or do you already have a header system in place and just want to replace the muffler.
Ove
Re: Exhaust system.
Post by Ove »
I'm going to use this 914 GB 2.0L (100hp) engine in my Replica Speedster 356, but I'm wondering
what kind of headers to use. Vintage Speed says they have headers for CJ only.
But is CJ the same as the heads on the GB ? (will they fit ?)
There is something about rectangular and oval exhaust ports I think ?
Good to hear that the super flow is not too loud, I have not decided to go for their "sport" or "super" version...
rgds
Ove
