body off build up
kombi211
body off build up
Post by kombi211 »
Well today i took a little break from the irs conversion and started on some of the body work well more like cleaning up alot of dirt and rust some one under coated just about everything and it does not like to come off easy. this is what i got done today.
lot of bad patch work that i will have to fix
43 years of dirt
inner panel removed so i can clean everything up
nos panel i have laying around
kombi211
Re: Time to do some body work
Post by kombi211 »
well I have been kinda busy lots of little projects going on. Just finished building a rotisserie to put the squareback on. So i can media blast the whole body. Plus i am in the process of building my version of the Volksair , Vw power air compressor so i have the air to do the job...
here are some pic of the square as it sits now
Bigvwhead
Re: body off build up
Post by Bigvwhead »
I love that rotisserie 8) way cool I'll be making one for my notch this summer and was wondering where and how you attached the body to t any close up pic's ?
thanks Bigvwhead
kombi211
Post by kombi211 »
thanks I Have a lot of repair work to do on my square and thought this would be the easiest way to get to all the hard to reach spots. I attached he front via the front upper beam mounts... And the rear from the rear sub frame mounts. the brackets for that is just 2inch angle bar welded to the slip pipe. It is 8feet long outside to outside of the up rights
Nos rear trunk flooring
PJsSquareback
Post by PJsSquareback »
Where did you get the NOS trunk flooring? Mine has several rust holes and I am considering replacing the whole thing.
Thanks,
Dan
kombi211
Post by kombi211 »
I got lucky i bought a whole stock pile of NOS type3 parts here. and ended up with 4 of the rear floor section good thing the one on my square back is trashed so very bad patch jobs all over it...
kombi211
Post by kombi211 »
well i was having no luck in finding time to strip all the rubber under coat off the squareback. they sprayed that crap everywhere inside and out to cover up some bad patch jobs. So i had to hire a guy to come over and do it for me.
So here is some of the progress...
jet strip at work
some of that bad patch work
major bondo in the hood
rubber under coat off of everything now
some one made galvanized floor pans for the square not to bad of a job
now in a coat of KBS
supaninja
Post by supaninja »
Looking good, any updates?
viewtopic.php?f=14&t=140387
kombi211
Post by kombi211 »
not much has been going on with the square. Just waiting on some tools to show up from the states and all all the rain to stop here. but will start back on it soon I hope...
kombi211
Post by kombi211 »
Been working on cutting out the rear cargo panel on the squareback. It was so badly beat up and patched over the year
It was best to just replace it. And being a happen to have a few NOS panels I am attempting it. Its a real pain in the ass
being almost all the spot welds are impossible to find from the patch work that had been done. But its out now...
the link below are to my photobucket
http://i154.photobucket.com/albums/s242 ... SC0639.jpg
http://i154.photobucket.com/albums/s242 ... SC0637.jpg
http://i154.photobucket.com/albums/s242 ... SC0636.jpg
http://i154.photobucket.com/albums/s242 ... SC0640.jpg
http://i154.photobucket.com/albums/s242 ... SC0647.jpg
http://i154.photobucket.com/albums/s242 ... SC0646.jpg
http://i154.photobucket.com/albums/s242 ... SC0645.jpg
http://i154.photobucket.com/albums/s242 ... SC0644.jpg
http://i154.photobucket.com/albums/s242 ... SC0651.jpg
still alot of work to be done But its getting there
supaninja
Post by supaninja »
Looking good dude!
BuBBaStuBs
Post by BuBBaStuBs »
I'm going to have to do the same thing to mine eventually going to get it torn down (Body off) and get her restored like I'm wanting to. Keep up the nice work on the square
"71 Volkswagen Squareback
