Dipstick comparision, 411 VS 914/4
Discuss with fans and owners of the most luxurious aircooled sedan/wagon that VW ever made, the VW 411/412. Official forum of Tom's Type 4 Corner.
sharkskinman
Re: Dipstick comparision, 411 VS 914/4
Post by sharkskinman »
so are we saying that on a stock T4 1.7 engine
that its ok or good to put an extra quart in it
maybe the 914 "Porsche" stick has the provision for the extra quart?
sharkskinman wrote:so are we saying that on a stock T4 1.7 engine
That's basically how it looks.
The blocks are identical.
Lars S
Post by Lars S »
Lars S wrote:Just discovered the difference in min/max marking on the dipsticks for a VW411LE and a 914/4, both from -72. As you may know the two veichles had almost identical 1,7 80hp D-jetronic engines.
The min on the 914 seems to be the max on the 411, despite this the sticks are identical.
In addition to this the 914/4 had a some extra arrangements in the crankcase to prevent high sea in the oil (at least from some year model).
/Lars S
The lower stick is the 914/4 one.
Drained and topped up the oil in my 914 today, the difference in volume at the different dipstick marks are are as follows:
Upper 411 mark to lower 914 mark: approx 100ml
Lower 914 mark to upper 914 mark: approx 350ml
That's OK with me but why does the 411 and 914 manuals list the same oil capacity?
/Lars
Perhaps the guy responsible for marking the 914 dipsticks drove one...
pig-pen
Post by pig-pen »
hello all.
can anyone tell me how long the dipstick tube should be on a 2.0L 914 motor. Mine is snapped.
I have a length of hose on there which the previous owner fitted. Its not ideal.
How far above the tin ware should the tube protrude, at least I can get the hose cut until my new tube arrives.
any ideas on how to fit it when it does?
thanks in advance!!!!
reluctantartist
Post by reluctantartist »
can you try the 914 dipstick in the 411 and vice versa? I would be curious to see where it reads. The 914 reads in a different location (?)
Lars S
Post by Lars S »
Yes I can swap the sticks between the two cars and the dipstick location and the dipstick tube length are identical.
/Lars S
