Cam shaft woes
- Bugmekanic
Cam shaft woes
I have just rebuild my engine, and installed a new scat c35 cam and new lifters (Brazillian, black box). After the cam break in period, let cool, readjusted the valves. Next day took the bug for a short run..No. 2-4 exhaust lobe went flat. Haven't torn the engine down for inspection yet. I know the lobe is shot, and I'm wanting to replace the cam with a different brand. I'm looking at Web Cams w/ thier lifters. My question is, I need some input on which cam would be best suited for my particular engine combo? Here are the specs on the engine...it will be a daily driven car that needs a little performance, but no dragracing.
1955cc 76X90.5
Straight cut gears
CB 044 Supermags 40x36
dual Dellorto 40's
Important! Stock ratio rockers only 1.1:1
moly push rods
dual springs
either 1 1/2 merged or 1-3/4 merged
In a full 69 beetle w/ 388 gears
Not sure if you'll need more info for an accurate recommendation, if so, just ask!
Thought I knew what cam to run, but got lost in all the specs!
Thanks! ~ Jack
1955cc 76X90.5
Straight cut gears
dual Dellorto 40's
moly push rods
dual springs
Thanks! ~ Jack
- James2
Sorry to hear your troubles.
I would run a web 218. it's slighly smaller then the Scat c35, but has more lift.
Currently their is no lifter made under 400 bucks a set that I would run. I found an old set of eatons that I'm running now.
To help save the next cam-
1) break it in with single springs
2) Go to a chevy dealer and get a bottle of EOS (Engine Oil Supplement) to add to your breakin oil.
3) Run a oil rated for Compressin Ignition service the first 500 miles. i.e. dello, rotella, delvac.
Both the supplement and diesel rated oils have larger amounts of ZINC. Zinc is a very effective anti scuff agent. It has been removed from most motor made for gas engines because it promotes slug build up and can damage some convertors.
Good luck
Good luck
- sparkmaster1
I broke my 1776 in with dual springs. It had DRD Stage 5 heads, Web 163, and Scat lube-a-lobe lifters with SLR treatment. I toar the engine down after 100 miles to look at the cam/lifters and they were fine. I'm not sure if it matters, but I spent alot of time making sure my valvetrain geometry was perfect.
Thanks,
Andy
Thanks,
Andy
- ErikTheRed
My $.02...........
Never had a problem breaking in a cam with dual springs, but I had a Web 86b go flat on me recently-- 3 lobes WIPED OUT-- using Brazillian lifters. Now its a FK-10, Scat lifters, SLR'd, and Bugpack springs--- broke in with BOTH springs again and all is well so far. Used Delo 400 and a bottle of STP oil treatment for break-in. BugBite, I think you will find you are in sparse company with the "never run in a cam with dual springs" opinion. Will it help? Im sure it will-- but most engine builders run it in with both springs installed without a problem. Springs alone are not the only cause for a flat cam!
For us California residents, unfortunately GM EOS is no longer available due to recent emissions laws. If you have a buddy out of state, have him send you a few bottles.
Also, I believe the new SC1 cam billets are a much better material than the older EP12 and ES12 blanks, hopefully we will see less problems with these.
The cam (grind and material), lifters (surface, coating, material, weight), spring pressure, lubrication, assembly, break-in technique/preparation, and valvetrain mass will all play a part in a flat cam. If any of it is wrong, you accellerate the risk.
