5x100 wheels 1967 beetle
You know, de-chromed, big Porsche rims, Brembos, etc.,... German Look rules!
vwinwv
Post by vwinwv » Tue Oct 04, 2005 2:52 pm
Just wondering if anybody has any idea where i could purchase front brake drums for a 1967 beetle drilled to a 5x100 bolt pattern. I found rear drums a couple of places but no front. Thanks!
Post by Marc » Wed Oct 05, 2005 3:16 am
Presumably you've found long-spline rear drums that'll need to be cut down to fit on `67 axles.
I've never seen any 5x100 (or undrilled) balljoint front drums either; unless you convert to disc brakes you'll probably have to have some `68-up 4x130 fronts redrilled. They'll fit the `66/`67/early`68 spindles provided the correct inner bearing & grease seal is used.
http://www.franklinsvwwerks.com/services.htm
vwinwv
Post by vwinwv » Wed Oct 05, 2005 7:26 am
Is there any place that you know of that has adapters for 5x205 to the 5x100?
Post by Marc » Wed Oct 05, 2005 10:37 am
You'd probably stand a better chance of finding some to go from 5x130 or 4x130 to 5x100 (but then you'd still have to change drums). Write one of these guys and see if they can make you some:
http://www.wheeladapter.com/
http://cgi.ebay.com/ebaymotors/ADAPTERS ... 3847QQrdZ1
eurit35
Post by eurit35 » Fri Oct 14, 2005 5:10 pm
vwfleh
Post by vwfleh » Sun Oct 30, 2005 7:13 pm
You will probably have to buy blank drums and have them drilled. I couldn't find any predrilled ones when I was looking so I bought blanks.
http://www.shoptalkforums.com/viewtopic ... highlight=
