any one use this? it fits in the frame tunnel to be used with the stock pedals.
I was hoping to get an idea of the pedal travel compared to the stock cable clutch.
Also does anyone know what sort of m/c do they use? looks like this
thanks
rip
Saco hydraulic Clutch
The pic didn't come through but I'm interested.
Jason
Jason
1960 "Bad Dub" http://youtu.be/VEUPxTw11hk
Drag http://youtu.be/NNcPQDiNPQE
Dyno http://youtu.be/51_JRESS0Tg
1957 "Ragster" http://germanlook.net/forums/showthread.php?t=11514
well that's odd, i've posted this on other forums at it came through.
well heres a url
http://community.webshots.com/album/233555749GQyeIi
thanks
well heres a url
thanks
Gotcha, thanks. So did that hole have to be cut, or can you install it through the shifter rod access hole on the front?
Jason
Jason
okay so i deleted the picture, it started going bad on me too.
so if you guys want to see it use the url.
I havn't done it, but from what I understand you need to cut the hole, it's in the instructions. this is because you need to bolt it up to the stock pedal assembly, and because it would be difficult to try and push the bracket to the pedals it's easily to cut the hole.
