996 headlight in bug fenders
You know, de-chromed, big Porsche rims, Brembos, etc.,... German Look rules!
DerrickfromNC
Re: 996 headlight in bug fenders
Post by DerrickfromNC » Mon Jan 17, 2011 8:41 pm
BOB JOHNS wrote:Thanks man for posting the headlights. Like the hood where did you score that at? Sweet ride 8)
CreativeCarCraft(CCC) when they were based out of Florida about 3 years ago. The owner at that time produced a couple for race cars and made one for me for a street car upon request. CCC has changed ownership and is now based out of Tenn.
DerrickfromNC
Post by DerrickfromNC » Tue Feb 15, 2011 2:27 pm
http://picasaweb.google.com/vwillo56/Po ... directlink#
Wife just purchased a set of the above Porsche Sport Design wheels off of ebay for my car. They will need to be refurbished....instead of silver I'm thinking of going either hyper silver like on the 2011 Nissian 350Z or a bright charcoal color.
18"x7.5" & 9" will be mounting a set of used run flat tires 215/40 and 255/35.
I was close to pulling the trigger on a set of 19's but I could not find an off the shelf Porsche wheel that was less then 8" wide for the front & I did not want to buy another front beam since the 2" narrow beam I have now has 0 miles on it.
BOB JOHNS
Post by BOB JOHNS » Wed Feb 16, 2011 12:02 am
Also i noiticed how your not running fender beading Mine is the the same way I love how that looks all crisp and clean .. nice ! my shifter from bug tech has arived its sweet ... here is a pic if you havent seen one before they are sweet !!
capsoval
Post by capsoval » Wed Feb 16, 2011 12:17 am
DerrickfromNC wrote:http://picasaweb.google.com/vwillo56/Po ... directlink#
I have that same style of wheel, I think they look great. :D
My Turbo Build>> http://www.shoptalkforums.com/viewtopic ... 9&t=122882
480whp/300wtq>> http://www.youtube.com/watch?v=6-RvkpiTmr4
Special Thanks to 55superbeetle, Jeff @ 40Thirteen fabrication
Flagbuggy
Post by Flagbuggy » Sun Jul 24, 2011 2:01 pm
DerrickfromNC wrote:993 headlights:
http://s1117.photobucket.com/albums/k58 ... 971c8d.png
Had a look at tehe pic and it looks blooooody HOT
DerrickfromNC
Post by DerrickfromNC » Thu Sep 15, 2011 11:53 am
Need suggestions for some easy(minimum of bodywork) to install modern LED style taillights in my fiberglass fenders. Was going to use a set of 67 taillights but my wife in her wisdom pointed out that I need something more modern to match my Porsche 993 headlights.
I am considering using a pair of Victory motorcycle taillights like these:
http://www.customdynamics.com/victory_l ... ro_kit.htm
Need some more suggestions please!
Thanks.
volkdent
Post by volkdent » Tue Sep 20, 2011 1:56 pm
I think red LEDs accross the bottom of the rear fenders would looks sweet....
I did this on the front fenders to act as DRLs, works really well. I drilled each hole at the correct aim angle, there is a black ABS plastic mount that I heated and moulded to the back of the fender to act as the LED holder. Then I used fiberglass to create mounting brackets on the ends of the holder.
If you do it, I found 10mm LEDs work great, look for high ouput (lumens/canadella, whatever) and a large viewing angle(25 deg or better, a lot are narrow angle, 10-15 deg). Even better if they are pre-resistor-ed to 12V, otherwise they are usually 2-4V and will need resistors added.
Jason
DerrickfromNC
Post by DerrickfromNC » Wed Sep 21, 2011 12:20 pm
Nice......can they be purchased with red and amber lenses?
volkdent
Post by volkdent » Wed Sep 21, 2011 2:52 pm
Yes, any color of the rainbow. I think the ones I used were 250000 MCD brightness. Red will be very bright, as well as amber.
Here's an example, not what I would suggest, but similar, only has 20 Deg viewing angle. Just start searching, Ebay is good from China, takes awhile but cheap. I would think not much more than $20 for the number you would need with shipping.
http://www.ebay.com/itm/10P-12V-DC-PRE- ... 43#vi-desc
Jason
h2odrx
Post by h2odrx » Tue Sep 27, 2011 3:51 pm
DerrickfromNC wrote:Nice......can they be purchased with red and amber lenses?
how hard is it to install the 993 lights?
1965 Ghia Vert
NC State law defines biodiesel as ''any fuel or mixture of fuels derived in whole or in part from agricultural products or animal fats or wastes from these products or fats.''
