Using Message body tool bar
Plastermaster
Post by Plastermaster »
I haven't figured it out. How do you use the boxes for italics, bold, etc. and how do you post a link to another thread. I tried the URL box but it just prints the words with [url] front and back.
Thanks
Ron
sideshow
Post by sideshow »
Just play around;
but use the preview button to check on your work.
The fastest way I have found is;
  • write what you want first
    ignore any formating
    then go back and block (using the mouse, click and drag)
    when blocked click on the the style
You will see the tags added
Now the links to others are a little tricky, but it is the same idea. I copy the URL from the browsers address bar, and do the same blocking to add the image tag.
Here is a SSC tranny;Image
