AE Accel-Pump issue
Moderator: Tom Notch
vwi_dduvall
AE Accel-Pump issue
Post by vwi_dduvall » Sun Nov 12, 2017 8:09 pm
Hello all,
It's been a long while now, been tinkering here and there and have things running fairly nicely so much so that this little 1600 now blows that old clutch away :-) Time for a new clutch :-) Any how I have one issue s whis I can't seem to work out I get a lean spike on accel after say sitting at an intersection for a long light, a rich dip in the AFR followed by a lean spike, I am using TPS and seems to get worse with MAP or any combination of both. I am ruining an MS3X with current firmware. I will try and get some logs of it as i know it's easier to help.
Thanks y'all,
Daniel Du Vall
Huntsville Alabama
Daniel Du Vall
http://volkswageninsanity.us
"Cause, remember: no matter where you go... there you are"
Buckaroo Banzai Across the 8th Dimension
vwi_dduvall
Re: AE Accel-Pump issue
Post by vwi_dduvall » Sun Nov 12, 2017 8:59 pm
OK here is a link to the tune and some longs.
http://volkswageninsanity.us/Postings/F ... E/12NOV17/
Thanks y'all,
Daniel Du Vall
Huntsville Alabama
Daniel Du Vall
