Strange "Rich" reading at 5000-5500 RPM, 95 KPA
Moderator: Tom Notch
CBDZ
Contact:
Post by CBDZ » Mon Nov 07, 2016 12:04 am
I have been creating high RPM, full throttle data-logs.
I keep getting a consistent rich reading right about 5000-5500 RPM / 95KPA. The data log shows that the AFR drops to 9.0:1 (about), which in turn makes the
'VE Analyze" pull out fuel in just those few cells. All the surrounding cells stay the same, which then creates a crater in my VE table.
Could this be caused by the Rev. limiter, which cuts spark, therefore confusing the system to think there is un-burned fuel, causing a rich reading? If this is the case, should I simply turn off rev. limiter, and tune this area, being very careful to not redline?
Is there something else that I need to adjust to correct my data collection?
My Car Details:
Fiberglass Buggy on 1973 Chassis.
1904 cc
Megasquirt (MS1 with 3.57 board) Fuel Injection: German Intake Plenum, CB Performance End-Castings, Ford Escort Throttle Body with custom Adapter, MS controls Wasted Spark Coil Pack
66brm
Location: Perth, Western Australia, The Southern Hemisphere
Re: Strange "Rich" reading at 5000-5500 RPM, 95 KPA
Post by 66brm » Mon Nov 07, 2016 1:51 am
Electrical misfire?
ps2375
Post by ps2375 » Mon Nov 07, 2016 10:30 am
Unburnt fuel does not cause a rich reading, as the O2 sensor measures oxygen, meaning if you have a lack of combustion, you will have a lean reading due to the abundance of oxygen. And a "crater" in your table means nothing, it won't be smooth and pretty like some people think it "should" look. Let the TS do it's job and see how it drives.
CBDZ
Contact:
Post by CBDZ » Mon Nov 07, 2016 12:29 pm
I've added another value to the log, and have realized that the injector duty-cycle is peaking at above 100. How could this be affecting my recorded data?
My Car Details:
1904 cc
ps2375
Post by ps2375 » Mon Nov 07, 2016 12:37 pm
If your duty cycle is above 100, you need bigger injectors or more fuel pressure.
