Two Step
clintonddk
Two Step
Post by clintonddk »
When I originally built my MS2 I chose to build the 2 step to trigger with a negative trigger. My question is, can I also change my line lock to trigger with the negative instead of a positive like it is currently triggered now.
Clonebug
Re: Two Step
Post by Clonebug »
clintonddk wrote:When I originally built my MS2 I chose to build the 2 step to trigger with a negative trigger. My question is, can I also change my line lock to trigger with the negative instead of a positive like it is currently triggered now.
Does your line lock go through the MS unit or is it just triggered with a switch???
If you are using a relay you can wire it to switch ground or power sides.
I have wired everything on my buggy to switch on the ground side.
The WI Hobbs work on ground..... the launch control switch on the clutch switches the ground side..... the switch on my shifter activates the launch control clutch switch by switching a ground on the relay.
clintonddk
Re: Two Step
Oh ya! That'll make life much easier. Thanks
