I installed 2 bip373s on a second heatsink on my v3.0 MS1 and tied the grounds to the bottom of the r43.
The control go through S4 and S5.
I didn’t add a separate db15. I just used S4 & S5 and I am using a relay board.
Question is, Is the ground lines on relay board circuit board strong enough to handle the ignition plus everything else ?
Reason why I ask is, I think I am burning up my relay board. I am not sure if it is because of the grounds or something else.
Can I just jumper from the relay board near the db37 to ground? Or would it be better to run a separate ground out of the MS1 case straight to ground from the bip373 ground pins ?
I am using shielded cables inside my relay cable for the ignition control and my VR in.
Eric
relay board and grounding issues? "letting out the smoke"
- Thorkhild
- Thorkhild
Re: relay board and grounding issues? "letting out the smoke"
Well it turns out the trace on the relay board for the s4 position was not up to the task. So I added a jumper wire from the pins on the underside between the db-37 connector and the s4 connector.
- gtmdriver
That's interesting.
I'm running an MS2 V3 and a relay board and I'm directly driving a Ford wasted spark coil pack and 2 banks of 2 high impedance injectors.
I'll keep an eye on the relay board. Thanks for the heads up.
- Volky
Hi,
I did not have your issue but I soldered a wire on the underside on a few traces, too. Better safe than sorry. :shock:g
1970 VW Beetle with 2109cc turbo with MS-II v3.0, wasted spark, electronic boost controller, dual table, launch control and 3.88 tranny. All done by me... t03 running 48lb. Injectors, Intercooler, Water/Meth injection at 15psi.
- Thorkhild
I ended up doing the same by adding extra wires under the relay board for my ignitor signals.
- Volky
Thor.....
How did it work out?
- Thorkhild
Its all good now !! now I just have to find time to tune.
And, fix all my turn signals, headlights, brakes ..... the usual aircooled maintenance required asfter sitting a while.
