Wideband controller
Wideband controller
What is everyone using these days for a wideband O2 controller. I currently have a LC-1 and I'm unhappy with it. I just got my cam broke in and I'm trying to tune in my idle before heading out for a drive. Now all my wideband O2 sensor reads is 7.4 and the LED wont light up so it's impossible to do a calibration.
Re: Wideband controller
Everyone has their favorites.
I had a LM-1 that died on me so I found the PLX brand that seemed to be a cleaner install. It had a controller that is separate from the gauge so I could easily hide it under my dash.
I have had it for at least 2 yrs without any problems. It never needs to be calibrated and the Gen 4 version even comes with the Bosch LSU 4.9 sensor.
It also has a multi sensor gauge that will display other controllers that can be daisy chained to one gauge.
Here is a combo set with gauge and Controller.
http://www.plxdevices.com/Wideband-O2-T ... 002719.htm
- ps2375
http://www.14point7.com/
Take your pick, I've never had problems with the stuff I've gotten from him.
Same here.ps2375 wrote:http://www.14point7.com/
The newer units can even read back WB sensor temps, and the higher end setups have all sorts of sensor/logging options.
- GoMopar440
I have the PLX Gen 4 combo kit to read A/F ratio. I don't have any experience with any other brands of A/F systems so I can't really give a comparison. It isn't installed yet either so i can't give first hand feed back yet. PLX does package their parts well and the pieces I received look to be of decent quality, so I have high hopes for it. I also like the fact that any future sensor module additions (up to 16) can all be daisy chained to the same gauge. I just got the O2 bung welded into my header pipe and will finally be able to start installing it soon. The weather even looks like it's finally turning around to where I can work on the rail outside now.
Home made rail (street legal), 1600 DP, 34PICT-3, T3 brakes, 4-1 glass-pack exhaust, 31's in back and 7.00x15's up front. Link to build thread: viewtopic.php?f=28&t=147561&p=1227553#p1227553
Thanks, I get the general feeling that no one has great success with innervation products. I do have a email into them to see if there able to help but, I do have an eye on the Spartan 2 controller.
- Max Welton
I started with Inovate stuff but switched to AEM several years ago. The in-line controller has worked flawlessly for a lot of all-weather daily-driver miles.
Max
Max
Innovate had all sorts fo problems with that particular unit, my brother went through two of them before giving up in disgust. I use Techedge stuff personally, but I also have one of Alan's early JAW units and it's been flawless since I got it.
Does anyone offer a DIY kit and has anyone ever had any luck with it?
clintonddk wrote:Does anyone offer a DIY kit and has anyone ever had any luck with it?
14point7.com makes a couple "kits", including one version that is fully Open Source, board design to firmware.
His almost top end unit is available in kit form (minus the SDcard support)
I got my JAW 1.03 (that I still use) broken, it was a kit to begin with, and I basically reduced it back to kit form and reassembled it. It has survived much abuse, including losing two alternator voltage regs that full fielded at 75 MPH, blew traces off the board at ~30V, but worked once I fixed the board.
(I upgraded to a 100A GM alternator to eliminate that issue with the junk external regulators)
I also built one of Alans "eval" kits, worked fine.
- woodsbuggy1
I have been using the MTXL for over 2 years with zero problems. I will be ordering another one soon for my new build. This is in my offroad car that sees a lot of abuse. The controller is built into the gauge which is very nice when space is a premium. These are available for $155 shipped on ebay.
Kenric
Kenric
AEM here...about a year old...been flawless
70, 74 beetle, 81 Chenowth, 66 Fastback, 83GTI, 85GTI, 02 GTI, 72 Std Beetle
