Doesn't idle when cold
maxyray
Post by maxyray »
Hi guys,
I'm running ts, ms1 with v2.2 board, have a wideband o2 sensor on a Turbo 1776 mexi setup.
It idles fine when hot but when cold I have to keep my foot on the gas otherwise it will stall.
I've tried using the warm up enrichment auto tuning tool in ts loads of times but it doesn't seem to help.
Any guidance would be great.
Max
Volky
Re: Doesn't idle when cold
Post by Volky »
Use the ASE to adjust the stalling.
Sent from my SGH-M919 using Tapatalk
1970 VW Beetle with 2109cc turbo with MS-II v3.0, wasted spark, electronic boost controller, dual table, launch control and 3.88 tranny. All done by me...:) t03 running 48lb. Injectors, Intercooler, Water/Meth injection at 15psi.
maxyray
Post by maxyray »
Volky wrote:Use the ASE to adjust the stalling.
Thanks for the reply. Whats ASE?
Max
afterstart enrichment.
What are you running for a idle air valve?
maxyray
Post by maxyray »
Piledriver wrote:afterstart enrichment.
It's one of marios kits and I don't think it has one.
Max
maxyray
Post by maxyray »
What should I do?
Max
Engine needs more air and fuel to start/idle cold.
If MS1E has a cold timing feature, add some.
Find and install a CIS idle valve?
Connect 12v from coil power, warms up and closes over about 2 minutes.
(obviously needs air hoses etc, grab the connector/pigtail too)
HPjunkie
Post by HPjunkie »
After start could be as high as 230% ! I just found this out, mine won't idle at 130%. I went to AMP clinic and got some tips. Sneak up on it tho
Clonebug
Post by Clonebug »
Here is mine for a 1679 cc engine. It will idle after 15 seconds on the throttle or if it is 50 degrees and higher will idle just by starting with the key.
I do have the warm idle set at 1000 rpm.
It will idle cold at about 600 rpm. It takes about a minute for it to warm up to normal idle.
It certainly is not perfect but it works pretty good.
maxyray
Post by maxyray »
Thanks for the help guys.
Max
