rebuilding relay cable
Thorkhild
Post by Thorkhild »
I have the one from DIYAUTOTUNE, but its too long and I am shortening it, and adding a couple of extra cables as well.
I added 2 shielded cables for spark outputs and put their shields into 14 & 15. (I am using 2 of the IAC ports for spark and the other 2 for additional sensors).
I am wondering if I should add more ground cables between the MS and the relay board while I have it apart.
Currently it has ground cables in 1, 16-19 for grounds.
1 is the shield ground for the tach/vr input.
Clonebug
Re: rebuilding relay cable
Post by Clonebug »
My Relay cable from Mario has every terminal wired straight thru.
If you have all the wires in there you never have to worry about adding something again.
