started my microsquirt install last week on my splitscreen panel type 4 2056cc (soon to be 2270cc).
started by mounting all the sensors + the microsquirt ,rellays and seprate fuse box
mounted the trigger wheel (marios type 4 kit)
[URL=http://s768.photobucket.com/user/d ... .jpg[/img]
[url
new microsquirt install
Re: new microsquirt install
40MM CB PERFORMANCE THROTTLE BODIES
STARTED WIRRING ON THE WEEKEND
[url
[url[url][URL=http://s768.photobucket.com/user/d ... .jpg[/img]
STILL GOT TO FINISH UP THE WIRRING NEXT WEEKEND
[url
i am just going to start with the ignition first
get that up and running with all sensors attached (iat , map , o2 wideband , coolent ect)
then get a base map for fuel of mario and set up fuel as well .
hopefully i should have ignition running this weekend
mounted al the digital dakota gauges
top- oil pressure , volts , oil temp , on dash gps speedo , fuel , cylinder temp
will match the innovative wideband gauge
- MarioVelotta
Looking good sir!! Think you will be running before years end?
[email protected]
[email protected]
got everything but the hall sensor wired .
having a little trouble with the hall sensor wirring
3 wires from the hall sensor have me a little stumped.
i just don't want to get it wrong .
so what goes where on the hall sensor(red , black, white) to the microsquirt
all sorted(thanks mario)damo99 wrote:got everything but the hall sensor wired .
