Realtime clock module
- vwi_dduvall
Re: Realtime clock module
Daniel Du Vall
http://volkswageninsanity.us
"Cause, remember: no matter where you go... there you are"
Buckaroo Banzai Across the 8th Dimension
just wanted to thank you guys for posting this as i have just added a RTC to my ms3x using a digilent 410-218 4 wires and its done for less than 10% of the cost.
I have ordered the digilent 410-218 RTC too. It's connected to my MS3 and I can set the time. But if I powercycle the MS3 it's loosing the time information. Back up Battery is mounted but doesn't back-up the unit.64 sunroof wrote: ↑Wed Apr 14, 2021 2:18 pm just wanted to thank you guys for posting this as i have just added a RTC to my ms3x using a digilent 410-218 4 wires and its done for less than 10% of the cost.
Did you have the same problem and if yes how did you fix it?
Solved, it's working now just repeated the set-up process 3 times...Frank914 wrote: ↑Wed Apr 28, 2021 2:34 amI have ordered the digilent 410-218 RTC too. It's connected to my MS3 and I can set the time. But if I powercycle the MS3 it's loosing the time information. Back up Battery is mounted but doesn't back-up the unit.64 sunroof wrote: ↑Wed Apr 14, 2021 2:18 pm just wanted to thank you guys for posting this as i have just added a RTC to my ms3x using a digilent 410-218 4 wires and its done for less than 10% of the cost.
sorry to bring up this old topic, but I've been looking for this alternative module for a while and Im so glad I found this.
would this module also work? It has the same name "Digilent 410-218", but a little different layout as the one in this topic:
https://nl.rs-online.com/web/p/clock-ti ... ls/1840476
I wired mine with 30ga kynar wire wrapping wire, then secured it with a blob of hot melt glue, additional dab to secure the battery.
I have the same one here, backside says copyright 2011.
