So I'm doing my spark table and wondering what the max advance a type 1 engine should be fed.
I have a 1835 with a turbo cam in it - but running N/A at the moment. The cam is a very flat torque curve.
So a dizzy would advance to around 36deg, but I'm finding maps where people are hitting 50deg off load and in the 40s on load.
What are the educated thoughts?
spark advance
- Devastator
Re: spark advance
During deceleration and cruise the advance can be upwards of 40 degrees. I'd keep it around 32 degrees max. under load, depending on your altitude of course. Good starting point anyway.
Devastator's Build Thread
Sandrail
going fast enough."
Mario Andretti
Sandrail
going fast enough."
Mario Andretti
Re: spark advance
have a look through my ignition only thread for my 1200 in IGNITION section... i got some maps there to give you a rough guide
