serial to usb adapter
westypoo
Post by westypoo »
needing info on how to get my computer to talk to MS. using a serial to usb converter. any help would be greatly appreciated.
Dale M.
Re: serial to usb adapter
Post by Dale M. »
This post has been edited to NOTHING because it contained bad information....
See post below for information believed to be correct on how to find Comm Port Number using a USB/Serial adapter...
Dale
westypoo
Post by westypoo »
ive downloaded the serial to usb adapter hardware. i go in and look at the settings and its on COM5 so i set my tuner studio to COM5, the baud rate is set to 9600. my MS is MS1 V3.57
Dale M.
Post by Dale M. »
And?
Dale
westypoo
Post by westypoo »
its still not working...ive made sure i have power going to the ms itself. i done have it hooked up to my motor as of yet, but it is all wired power and ground wise so that i can start playing with things. the power i have going to the ms unit is ignition.....so key on power. ive tried with both key on and off positions.
westypoo
Post by westypoo »
ok so i open the settings for the serial/usb adapter and here is the first screen that i get
and when i hit the "advance..." button i get this screen...
you
Post by you »
i have had issues with cheap converter cables
supaninja
Post by supaninja »
i'm on the usb/serial converter that diyautotune.com sells. I changed my computer settings to assign COM1 to it. I'm a bit re-re sometimes so I had commo issues because my MS1 was on regular code and I switched my laptop to extra code. once I uploaded the extra code to the MS1 all was well and I had coms.
viewtopic.php?f=14&t=140387
Dale M.
Post by Dale M. »
I think I have given you some BUM INFORMATION.... Number I gave you for "Comm Port" is wrong ( its not in USB View) ....
Try this, in Windows, go to CONTROL PANEL >> SYSTEM >> HARDWARE >>DEVICE MANAGER>> and scroll down to "PORTS" the USB/Serial convert should be listed there with its port number....
I apologize as its been years since I did anything with serial ports.... I used to be quite good with serial ports and hardware, now a days they do not even put serial ports on computers....
Dale
westypoo
Post by westypoo »
ok heres the screen i get after ive done what you have said.....
also whats the com port num? i set it to com1 if thats what your talking about. and still nothing. i also have my MS wired without using a relay board, but everything is wired as it should be! also i have a netbook (Eee PC running windows 7 starter edition) just incase that changes things.
supaninja
Post by supaninja »
is there firmware loaded on your MS?
Dale M.
Post by Dale M. »
Is that the port "Device Manager" says the USB/Serial adapter is on?
My only reference I can relate to is my desk top machine... Don't have a laptop (or net book ) at the moment... And its going to be different (comm port number) depending on whatever computer adapter
is used with...
Dale
supaninja
Post by supaninja »
my laptop is on ista and thats what it says too
westypoo
Post by westypoo »
from my understanding their is firmware loaded onto the ms. i bought this unit from Eric Allred (eallred here on stf) and he has a map currently loaded on the ms unit.
yes, this is the screen that pops up when i click on the "ports" in device manger.
supaninja
Post by supaninja »
alright when you open up megatune>communications>settings
make sure it says:
COM1
10
9600
then click to test. if your firmare is good and your USB/serial adapter is working properly it will be talking.
I just read your reply, do you have the same version of MT on your computer or a newer one?
