T3 megasquirt II conversion
Moderator: Tom Notch
Max Welton
Re: T3 megasquirt II conversion
Post by Max Welton » Mon Sep 09, 2013 1:34 pm
It turns out the pin Mario used for spark-B has no wire on the old harness I'm using. Oh well. :wink:
But DIY has a little $3 kit for adding a pin to their DB37. While I'm waiting for that I have the MS set to 'single coil' and am driving around with the IGN wire looped over the back seat and under the engine cover to the coil. It works! Using a timing light I was able to dial in the offset so that the advance happens right where MS says it is. Way cool!
Max
MarioVelotta
Post by MarioVelotta » Tue Sep 10, 2013 9:25 pm
Ahhhh yeah!
Mario@thedubshop.net
2276 Turbo - 92 Octane
11.537 @ 115.74mph - 15psi
1600 S.C. - ?sec @ 10psi (so far) 8)
1600 NA ITB - 18sec :lol:
Post by Piledriver » Wed Sep 11, 2013 12:30 am
Max Welton wrote:It turns out the pin Mario used for spark-B has no wire on the old harness I'm using. Oh well. :wink:
Max
"The nice thing about standards is there are so may to pick from "
Tannenbaum, Author of Minix OS and a number of related books.
(AKA The professor who gave Linus Torvalds an F in OS design, as he didn't follow instructions)
Max Welton
Post by Max Welton » Wed Sep 11, 2013 9:23 am
So I now have the add-a-pin kit from DIY and need to pick a time to take the car out of service and install it.
So with the IGN4 coil-pack, what would be the recommended spark-plug gap? Also, anything in particular I should set for dwell control?
Max
Steve Arndt
Post by Steve Arndt » Wed Sep 11, 2013 9:42 am
I run .035" gap, NGK resistor plugs, CB magna wires. 2.5 ms dwell at idle, and I ramp up the dwell based on manifold pressure. (with IGN1 coils)
Devastator
Post by Devastator » Wed Sep 11, 2013 11:06 am
I'm running AC spark plugs. .030 gap. These dwell settings with my IGN4:
Devastator's Build Thread
Sandrail
2276 ACVW
MS2Extra EFI W/spark
T3 Turbo making 10 lbs boost
Burning E85
going fast enough."
Mario Andretti
Max Welton
Post by Max Welton » Wed Sep 11, 2013 11:49 am
Very cool Guys. Thanks.
Max
aircooledtechguy
Post by aircooledtechguy » Wed Sep 11, 2013 2:03 pm
I've got EDIS on my car so I don't know how that compares to your coils (you all would know better that I), but I'm running ND Irridium plugs with a gap set in the .040"-.045" range on my 2056cc T-4. I can't remember exactly what I set it to now as it was a couple years ago. . .
Getting old sucks; I don't recommend it. :wink:
Max Welton
Post by Max Welton » Wed Sep 11, 2013 7:05 pm
“Getting old is not for sissies.”
― Bette Davis
Max
Max Welton
Post by Max Welton » Sat Sep 14, 2013 6:09 pm
Done. The only hitch was hooking up sparkA and sparkB backwards.
Max
Max Welton
Post by Max Welton » Mon Sep 16, 2013 7:34 am
Well ... not quite done. :?
The engine starts great and runs fine ... for a few minutes. Then it shuts down. If I cycle the MS (key off, then on), it will again fire right up and run for a little while before shutting down again. I've posted my problem in the msextra forums.
http://www.msextra.com/forums/viewtopic ... 75#p377060
Note that I've been driving it for about a week in single-coil mode without a hitch. So this has something to do with the switch to wasted spark. I do have the MS3 I got for the KG that I can plug in and try. If it works that should rule out the harness and IGN4.
Max
Devastator
Post by Devastator » Mon Sep 16, 2013 9:15 am
I had the same problem when I first switched to Hall sensor, wasted spark, 36N1 wheel, MS2Extra, and a second coil driver. The sensor I used, (from DIY), does not like temperatures over 250F or a gap over .04. After modifying my Hall sensor mounting bracket several times in order for it to cool better, (see build thread), I discovered that the bracket was getting just hot enough for the sensor to pull away from the wheel, increasing the gap, and shutting down. Let it cool, and it would run fine again. Reducing the gap cured this. My current gap is around .020, and it never skips a beat now. Hope this helps.
Sandrail
2276 ACVW
Burning E85
going fast enough."
Mario Andretti
Max Welton
Post by Max Welton » Mon Sep 16, 2013 12:47 pm
Thanks. But I triggered off this VR for 5 days of daily driving and this ECU without a hickup. So I think that part is solid.
What I will do tonight is take the top off the MS-2 enclosure and aim an IR thermometer at the various components (the new coil driver in particular) and look for hot-spots. I will also take the external temp of the IGN4 while I'm at it.
Another thing I know is that ignition and fuel are both going away together (consistent with ECU processing stopping). I know this because the engine isn't flooded when I go to restart it.
I will also plug the MS3/MS3X box in and see if it does any better. The MS3 ECU also uses pin-6 for spark-B. So Mario got it right. ;-)
Max
Devastator
Post by Devastator » Mon Sep 16, 2013 12:52 pm
Max Welton wrote:Thanks. But I triggered off this VR for 5 days of daily driving and this ECU without a hickup.
:oops: My bad. I thought you were using the DIY hall sensor.
Sandrail
2276 ACVW
Burning E85
going fast enough."
Mario Andretti
MarioVelotta
Post by MarioVelotta » Mon Sep 16, 2013 8:09 pm
I finally had a few minutes to look over your logs and MSQ. Looks like you upgraded firmware, did you go through and verify all the settings? You made a large firmware jump.
In the logs your MAP is jumping upto 255 right before you loose sync.
The next thing is ignition setup. VR should be falling edge. Otherwise you will get the double missing tooth.
The 182° trigger angle may be playing a part in the madness. I didn't think it would work that far off.
