Willo gets it. In my case there will be no points (or magnets) in the distributor. The trigger-wheel and VR sensor will be supplying the tach and ignition timing reference. So the only thing advancing in the distributor will be the rotor.Piledriver wrote:...Consider: ... the mechanical advance moves the whole upper section of the shaft, points cam (or magnets) as well as the rotor. If it was ONLY the rotor advancing, it would be OK, but it isn't.
Now, I may yet go full-on wasted-spark and no distributor at all. I have mentally committed to having the ECU mods done for me, so I've accepted at least a week of downtime for that. Plus I won't be worried about having some weird problem with the ECU.
So, if I have two coil drivers I could either use one coil (firing through the rotor - distributor) or ... what is a good wasted-spark setup?
Max
