MS 1 Extra V2.2 TPS Calibration
- 56speedster
Had a problem with my alternator and fan and had to remove the TPS and throttle body to fix it. When I reinstalled everything, I figured I should recalibrate my TPS since I had removed it from the TB but for some reason when I get the currents and click close, I get the following message: "Unable to save TPS calibration".
Anyone else ever have this problem and if so what was the fix? I posted this issue on the Megasquirt forums Friday but have no responses yet.
The car runs fine but I know that there is a difference because my static position used to be 18% and it is now 16%. I would rather recalibrate it with MS than move it on the TB until it reaches 18% because who knows if the currents would be exactly the same or not?
Any suggestions/help is appreciated.
p.s - I am really digging the MS F/I setup with the EDIS. Had I done this from the very beginning I wouldn't have a huge box of parts that need to be sold....
Re: MS 1 Extra V2.2 TPS Calibration
People never believe me when I tell them how good EDIS is, it's something you have to experience for yourself I guess.
- MarioVelotta
There should be a log file in your project directory, can you post it? It may tell us the problem.
[email protected]
[email protected]
- 56speedster
I'm guessing that would be different than the standard datalog. I'll look on the laptop and see if I can find it and post it.MarioVelotta wrote:There should be a log file in your project directory, can you post it? It may tell us the problem.
By the way Mario - I ran the car for a good 15 minutes while datalogging and then ran the VE analyzer in MLV and it made a bunch of changes that I ran today and it ran great!. I didn't log todays run but will try to tomorrow as I will be driving it every day for the next few weeks unless something breaks. As always, thanks for all of your help.
- 56speedster
In my projects folder, I do have a projectCfg folder that contains 3 files: mainController dated 4/15/10 that is 181kb, project.properties dated 5/9/10 that is 1kb and vehicle.properties dated 5/6/10 that is 1kb. Are any of the above useful in helping find the problem?
The only other folder in this project folder is the dashboard folder.
I do have some other msq files in this folder along with 1 datalog from yesterday and 2 other files: msns-extra dated 10/29/07 that is 182kb and msns-extrajs dated 4/15/10 that is also 182kb. I believe the later file is something I must have created as it has my initials at the end.... Could it possibly be the culprit??? I'm betting if something is wrong that I did it.
- 56speedster
Are any of the files listed above of any use in finding what could be the cause?
- MarioVelotta
The log file is in the main projects directory. Not your specific folder and it will be a .log file. Can you try un hooking the TPS connector and then trying the calibration again to see if you get the same error.
[email protected]
[email protected]
- MarioVelotta
Here is the error in that log file
5/10/10 5:59:35 PM :Error Reported: Unable to save Throttle Calibration.
Error writing C:\Documents and Settings\ndefranco\My Documents\TunerStudioProjects\JimmyStout\inc\throttlefactor.inc
The system cannot find the path specified
I'll email you the file if you can place it.
[email protected]
[email protected]
- 56speedster
Worked like a champ! Thanks Mario!
- MarioVelotta
Glad I could get it taken care of Now drive the crap out of it, and keep those poles and hydrants alone
[email protected]
[email protected]
- 56speedster
U-da-man Mario! Excellent product, excellent service and really good advice.MarioVelotta wrote:Glad I could get it taken care of Now drive the crap out of it, and keep those poles and hydrants alone
