Accel pump enrichment Issue MS3X
Moderator: Tom Notch
vwi_dduvall
Contact:
Post by vwi_dduvall » Mon Sep 03, 2018 11:07 am
Issue: Lean spike after rich spike (or dip on graff for enrichment) this issue is better during the morning hours when the temps at cooler roughly in the 60-70 F.
As the temp goes up above 70 say 80 it gradually gets worse. I have tried all TPS and all MAP and different mixes of both with no success.
I am probably missing something somewhere if anyone has any ideas or input I am all ears.
This setup is on a 1600 type3 with MS3X and 24 tooth distributor sync.
Wideband O2 full sequential
I can provide a log and tune as needed.
Thanks,
Daniel Du Vall
Daniel Du Vall
http://volkswageninsanity.us
"Cause, remember: no matter where you go... there you are"
Buckaroo Banzai Across the 8th Dimension
vwi_dduvall
Contact:
Re: Accel pump enrichment Issue MS3X
Post by vwi_dduvall » Mon Sep 03, 2018 5:17 pm
Here is a link to the last set of logs and the project backup:
http://volkswageninsanity.us/Postings/F ... 8/01SEP18/
Thanks,
Daniel Du Vall
Daniel Du Vall
vwi_dduvall
Contact:
Post by vwi_dduvall » Wed Sep 05, 2018 9:18 pm
Bump!
Anyone?
Please
Daniel Du Vall
Daniel Du Vall
Post by Chip Birks » Wed Sep 05, 2018 9:37 pm
Haven't looked at logs yet, on my phone right this second. Do you have it set to the accel pump carb like setting? I haven't really spent much time messing with my accel settings, other than to set them to that.
vwi_dduvall
Contact:
Post by vwi_dduvall » Wed Sep 05, 2018 9:55 pm
yes carb like setting/
Daniel Du Vall
