Confused on choosing TB for 1915 engine
Moderator: Tom Notch
bakakon
Post by bakakon » Sat Sep 15, 2018 5:22 am
A friend sold me his MS3 for cheap, so I'm now on doing FI route. On selecting throttle bodies, should CB's 40mm TB be enough? But which one? TB with injector ports or with none?
Also, if you have better TB in mind, would love to hear them.
andy198712
Re: Confused on choosing TB for 1915 engine
Post by andy198712 » Sat Sep 15, 2018 10:45 am
so you need to mount the injectors somewhere, if you went with the NONE option above, you would EFI manifolds to mount the injectors there....
if you already have twin carb manifolds, and linkage ect it would be cheaper doing it this way and having the injectors in the TBs.
OR
go single TB and EFI end castings, depends what you want from it.
what are you power goals, and future plans?
bakakon
Post by bakakon » Sat Sep 15, 2018 12:18 pm
Thank you for the clarification. I was confused when I noticed CB is also selling manifolds with injection ports. Idk how much power the motor has. It's a 1915, w120 cam and a Panchito heads. Are CB's 40mm TB too big for my use? What other ITB's do you suggest, and where to buy them?
sideshow
Post by sideshow » Sat Sep 15, 2018 9:00 pm
Packaging, what do you want? A single is less hassle than linkage, but you also have a fairly big camshaft that might be best with IR.
Of course if you force feeding air into a single seems to nullify most concerns.
bakakon
Post by bakakon » Sat Sep 15, 2018 10:29 pm
I am doing twin ITB.
sideshow
Post by sideshow » Sat Sep 15, 2018 11:44 pm
Well then the sky is the limit, plenty of choices. IDF patterned are by far the most common with lots of choices most hold the injectors in the throttle body, a few have them in them in manifold holding injectors (this decision may be made for you if you don't have the room).
Take a look at https://vwspeedshop.com/home.php?cat=395
Personally I like the SP1 as it looks the most compact but not really true IR, the IDF/IDA style are more popular.
I've heard the CB stuff isn't bad but there are lots of other players, Jenvey, Weber, you really need to figure out what you want before asking vague questions.
bakakon
Post by bakakon » Sun Sep 16, 2018 2:34 am
Quick question, what does IR means?
66brm
Post by 66brm » Sun Sep 16, 2018 3:29 am
Individual runner, means you have a single throttle plate per cylinder
Paul H
Post by Paul H » Sun Sep 16, 2018 10:34 am
Your motor would make about 130hp at the flywheel on my dyno and a set of 36mm IDF throttles will flow over 150hp so I'd use a set of those for best driveability. They are available with inside mount injectors which makes install easier in a bug
Real parts=Real Performance-Get Real
Opinion is the medium between knowledge and ignorance (Plato).
bakakon
Post by bakakon » Mon Sep 17, 2018 1:43 am
Do you have any leads where to buy 36mm IDF throttle bodies?
Post by Chip Birks » Mon Sep 17, 2018 8:31 am
I'm sure Paul would gladly sell you one of his sets. They are very nice. I've handled some of them recently. Vwspeedshop.com
bakakon
Post by bakakon » Mon Sep 17, 2018 9:58 am
Already checked his site, and the smallest throttle body he has is 38mm.
andy198712
Post by andy198712 » Mon Sep 17, 2018 11:59 am
Email him via his website and he gets back to you quickly, He recently sorted me out with some SP1 manifolds (no throttle plates in) and ducting to a billet single TB.
Couldn't be happier, the TB is a thing of beauty, and the manifolds are well built and plenty of room for any ports you want, service was great.
but i wanted single TB as i want to go turbo....
but theres alot of different options about and its just personal preference really :) if you went with VWSPEEDSHOP you wouldn't be disappointed
Paul H
Post by Paul H » Mon Sep 17, 2018 3:58 pm
I don't have the 36mm listed at the moment but they look like this
I use a return spring like the orginal Solex on each side for better return
These are inside mount injector with stainless fuel rail
bakakon
Post by bakakon » Mon Sep 17, 2018 7:13 pm
Woot woot. Thanks. How much are you planning on selling that?
