Idle issue cb performance
Moderator: Tom Notch
nic
Post by nic » Tue Oct 25, 2016 10:22 am
Hi,
I have a bit of a idle issue I'm fighting
Idle will start around 1100 and then for no reason is will drop to 700rpm
I have checked the basics air leaks etc
I've also attached the ecu log from my CB set up (not the best i know) showing my Map sensor and the rpm and you can see the revs drop.
Any advise would be appreciated
Compositecrafters
Re: Idle issue cb performance
Post by Compositecrafters » Sat Jul 21, 2018 9:17 pm
I guess you figured it out?
