NEW IDF Throttle bodies
Re: NEW IDF Throttle bodies
What intake runners do they go with?
1981 Volkswagen Vanagon Westfalia - air-cooled Type4 1970cc CV (hydraulic lifters, 42x36 valves, stock cam, microSquirt FI)
1993 Ford F-250 XL LWB Extended Cab 7.3L IDI
- MarioVelotta
They are based on IDF manifolds
[email protected]
[email protected]
just got the call from my engine builder engine is almost fuly mapped now and making good power there is still some smoothing of the map but my 2276 with 10.1 cr a 120 cam stock rockers stock ali pushrods and GAC wedgeports
made 169.8 fwhp at 6k very happy with the speedshop idf 45mm tbs, the kit is well made and everything does what it should
came with a base map already installed on ecu
GAC motorsport is a company in uk that build formula v racecars
not sure on the flow figures but i can find out
Will these TB's accept a standard IDF type oval filter and maintain the same or lower height that the IDF carbs will? Looking for FI for my oval but height is an issue.
- MarioVelotta
Yes, you can get IDF adapters.
[email protected]
[email protected]
Have the IDA pattern bodies been released yet? If so how can I order them?
- Paul H
IDA throttles have not been made yet
What is the current price for the IDF ones and can they be purchased through you or is there someone in the states who is importing them? Thanx.
check Mario, a few posts up
