CHT gauge and sender suggestions.
Devastator
Post by Devastator »
i was wondering what you guys suggest for a cylinder head temperature setup.
I was looking at this: http://www.atvrideronline.com/newsfront ... to_07.html
If I posted this in thw wrong place, Mods, please move it to wherever it is better suited.
Devastator's Build Thread
Sandrail
going fast enough."
Mario Andretti
MarioVelotta
Re: CHT gauge and sender suggestions.
Post by MarioVelotta »
I use the sensor connection thermocouples and digital gauges.
[email protected]
Devastator
I don't always run my computer though....
Sandrail
going fast enough."
Mario Andretti
MarioVelotta
Won't need it :)
[email protected]
Devastator
Oh. Cool!
Where do I get one?
Sandrail
going fast enough."
Mario Andretti
MarioVelotta
Thesensorconnection.com
[email protected]
Devastator
Thanks!
Sandrail
going fast enough."
Mario Andretti
MarioVelotta
No problem sir!
[email protected]
fusername
Post by fusername »
dakota digital also makes em. The only real pointer I can give you (I made my own lol) is make sure it is temperature compensated. Most guages only read relative temp with thermocouples, meaning your engine temp reading you need to add or subtract the difference between 70 deg and the current temp of your guage dial... kinda annoying.
andy198712
Post by andy198712 »
Devastator wrote:i was wondering what you guys suggest for a cylinder head temperature setup.
cable seems pretty short? price is good though!
Steve Arndt
Post by Steve Arndt »
I got my sensor connection thermocouple ring from Mario. I run a dakota digital dash gauge. I run a second TC that I can view in my ECU/data log.
tbirdusa
Post by tbirdusa »
Got the same gauge from Auberins.com. Had to get ten bucks worth of tc wire and extend the cable though. But, that was cool cause to get the engine out you really need a connector on the tc anyway. I was having to remove it from #3 and i had it under the tin. Sucked.
