New Intake
- Wally
Re: New Intake
www.apfelbeck.nl
www.apfelbeck.nl
Re: New Intake
Please educate us on your flow numbers? Did you compare to other intakes?
Steve
My Baja Build
My Baja Build
- Wally
Re: New Intake
We could only compare to my former 1600i manifold that we measured with and without last year. That gave way less CFM.
The SP1 manifold gave a very nice positive CFM hence the
I can't disclose how much exactly as I might need the flow sheets for a magazine article.
So, sorry, no numbers, I can only confirm that the manifold works (very) well for me and that it was educational to learn what makes the numbers rise and what does not.
www.apfelbeck.nl
www.apfelbeck.nl
Re: New Intake
cool, whats your new target for the 1200 then?!?!?
- Wally
Re: New Intake
Same as last year: 200 flywheel hp or 175 wheel-hpandy198712 wrote:cool, whats your new target for the 1200 then?!?!?
www.apfelbeck.nl
www.apfelbeck.nl
Re: New Intake
Wally wrote:Same as last year: 200 flywheel hp or 175 wheel-hpandy198712 wrote:cool, whats your new target for the 1200 then?!?!?
bet your feeling more confident this year
- Paul H
Re: New Intake
Here's a shot of the 58mm
Each half is the same area as a 43mm diameter circle
You can just see the high mount injector ports coming through-they aim straight into the middle of the intake port
Re: New Intake
Thanks for that picture.
How do you have the vacuum ports configured and placed? Is there a single, or two ports for each?
Steve
My Baja Build
My Baja Build
- Paul H
Re: New Intake
Steve
If you mean the vac take off for map sensor,servo,regulator etc then you can
see those on the very first pic on this thread-just hiding behind the throttle lever.
1/4npt both sides
1/4npt both sides
- Kalle
Re: New Intake
Thanks Paul, here is a test mock up I did today from some 3" pipes before I go ahead and order alu pipes and bends. It will be a T like you say due to space issues but inside the T I will bend a thin plate into a V shape and weld it on the "roof". I will hide the vacuum ports and the BOV on the back of the "plenum" tube. On each side I will use silicone bending reducers and I will also make two fasteners so that I can bolt the plenum on the two upper bolts for the alternator/fan house. The total length of the plenum is 82 cm. so the volume will be 2.3 - 2.4 liters which is quite close to where I wish to be.Paul H wrote:Looking good
Personally I'd go for a Tee section in 2.5 for three reasons :-
Firstly- I don't think you would gain anything from a fancy seagull tee or Y section
Secondly -the fabricated Y will add a lot more length and maybe give you headaches with clearance especially with the barrel chargecooler.
Thirdly- In effect you will be splitting the runner and then the up pipe or cooler becomes the "plenum chamber" which may or may not have an adverse effect
With that charge cooler I'd even be tempted to weld a 2.5 or 3 inch diameter pipe straight across the outlet and then neck it down to 2.25 to take the silicon hose for a very compact induction
-BB-
- Paul H
Re: New Intake
Kalle
That looks very neat and tidy.
Are the bends 45 degree at each end and then you will use 45 degree silicone reducer bends ?
Do you think the deck lid will close without standoffs ?
Cheers
Paul
Cheers
Paul
- Wally
Re: New Intake
I am dead certain it will. I know Kalle will not leave home before that is accomplished againPaul H wrote: Do you think the deck lid will close without standoffs ?
Cheers
Paul
He doesn't even have cut his deck lid for vert breathing vents...
Damn purists!
www.apfelbeck.nl
www.apfelbeck.nl
- Kalle
Re: New Intake
Thank you guys,
Yes I will be able to close the lid without stand offs. I will place the plenum tube as close to the fan house as absolutely possible and it runs "behind" the breather filter in the picture even though it is difficult (read impossible) to see on picture above. You're right Paul, the bends are 45 degree and I will use 45 degree silicone reducers instead of gradually decreasing the size on the pipe itself. I think that will work fine. I will either polish the whole intake system or get it (including the IC) powder coated satin black with wrinkles.
-BB-
-BB-
- Paul H
Re: New Intake
Kalle I prefer the polished ally myself
Just started to port a pair of 58mm manifolds to match up to some CB Ultramags (big oval port)
There is plenty of material to take out but it shouldn't take too long with the monster die grinder
I acquired recently
I acquired recently
- Wally
Re: New Intake
Picture! pretty please..Paul H wrote: the monster die grinder
I acquired recently
www.apfelbeck.nl
www.apfelbeck.nl
