Fuel pressure regulators
Moderator: Tom Notch
Re: Fuel pressure regulators
Post by Piledriver » Tue Jun 02, 2015 12:58 pm
You are usually far better off with an Airtex pump from ebay than a pump from a junkyard...
Esp due to the fact that the junkyard pump had probably been dry for awhile as junkyards drain or remove the fuel tanks.
sideshow
Post by sideshow » Tue Jun 02, 2015 11:00 pm
I've been tempted to buy one of these adapters;
http://www.rossmachineracing.com/fuelpresregadapt.html
Despite the text warning that this adapter rejects donor parts :roll:
Junkyards are hit and miss, last week I went for the first time in more than a year, pulled a RBV ('86-87 ford 2.9l) based filter and high pressure pump. Judging by the quality and volume of gas I found when I cut the line at home I suspect it is in perfect shape. Alcohol kills over time.
kangaboy
Post by kangaboy » Mon Jun 15, 2015 12:26 pm
Piledriver wrote:You are usually far better off with an Airtex pump from ebay.
Any idea what P/N I'm looking for?
This one? http://www.ebay.com/itm/Fuel-Injection- ... 24&vxp=mtr
Clonebug
Post by Clonebug » Mon Jun 15, 2015 9:15 pm
That one won't work without machining the fuel rail to hold it on.
It is designed to mount right on a fuel rail that has an injector fitting on the end and bolt mounts for it.
A Stock German VW Beetle FI regulator will work.
Post by Piledriver » Tue Jun 16, 2015 3:19 am
You were asking about a used pump and regulator.
I suggest new unless you like gambling.
I have had good luck, but know what to look for by now
(recent arrival etc, found one cherry looking Audi 4000S i wanted to take home as they unloaded it from the truck but they wouldn't sell it to me :evil: )
YMMV.
kangaboy
Post by kangaboy » Tue Jun 16, 2015 9:43 am
I know you suggested new, thats why i was looking for an Airtex pump on eBay like you suggested...unless that was sarcasam...and now I'm confused again :? . Ill just get a damn FI Beetle/Bus regulator and be done with it. I was just running out of money for the project and didn't realize that they were ~$100 new.
Post by Piledriver » Wed Jun 17, 2015 2:27 am
No sarcasm here, I said "airtex pump" and you asked about an airtex regulator...
The Bosch regulators can be had for less that $100 if you look around, they are not sold for the original application, they make djet regulators with vacuum ports that are great general purpose adjustable regulators with a 1:1 rate on the vacuum input, or you can run as fixed pressure if NA.
kangaboy
Post by kangaboy » Wed Jun 17, 2015 11:03 am
Piledriver wrote:No sarcasm here, I said "airtex pump" and you asked about an airtex regulator...
*FacePalm*
kangaboy
Post by kangaboy » Wed Jun 24, 2015 11:37 am
http://www.cbperformance.com/ProductDet ... tCode=7162
Yay or Nay. I have a single throttle body, so it fits my application.
Two questions from this: Does the single vac port on the regulator go straight to the TB?
What port does MegaSquirt get its boost reference from?
Post by Piledriver » Wed Jun 24, 2015 1:03 pm
kangaboy wrote:http://www.cbperformance.com/ProductDet ... tCode=7162
The answer to both latter questions is "to a manifold vacuum port".
The port on the TB is frequently ported manifold vacuum from a drilling just above the rising edge of the butterfly:
This is what you'd use for a vacuum advance can, but not a MS or FPR reference, as it's shuts off with the butterfly closed.
Max Welton
Post by Max Welton » Wed Jun 24, 2015 2:48 pm
Look for Airtex E2000.
Max
