H-30-pic issues.
Moderator: Tom Notch
PappaTiempo
H-30-pic issues.
Post by PappaTiempo » Wed Jan 08, 2014 8:10 pm
Picked on of these up from cb. I had issues with my 34-pict-3 and never really liked them for off road. Now my 30 has similar issues. It ran great when I put it on. Took it for a 1/2 mile hot lap and all was good. The next morning, it would not idle above 500rpm and the throttle killed it. I have replaced the fuel and put a facet pump on it(PO had pump det up wrong @ about 10psi) Questions.......Is the pilot jet attached to the fuel cut off solenoid? If not, where? I don't see a main jet, not in the bottom of the bowl at least. Thanks.
bajaman73
Re: H-30-pic issues.
Post by bajaman73 » Fri Jan 10, 2014 4:26 pm
The main jet is in the bowl plug. Unbolt it and turn around. you will see it then. Good luck
1972 VW Bus - 2.0Lw/36 Dellortos, 091 (Vacation Mode/Camping/Meets)
1967 Beetle - 1835w/40 HPMX, KCR Trans (Weekend Warrior)
1969 Beetle - 1641SP - (For Sale- Driven Occasionaly)
1970 Ghia - (For Sale - No Engine, Needs Work)
PappaTiempo
Post by PappaTiempo » Mon Jan 13, 2014 10:48 pm
Ya, found it the other day. New carb, stuck needle/seat. CB is sending me the new valve. Thanks for your help.
