How do you spell KADRON
Moderator: Tom Notch
Post by david58 » Thu Jul 11, 2013 10:01 am
I have a 2005 Yamaha V Star 1100 it originally came with dual carbs. After trying to rejet the carbs due to it popping out the exhaust on deceleration and spending 150 bucks on jets, then breaking the prongs of the slide that hold the needle jet. I decided to get crazy. So I made a intake for a 2 barrel Zenith I had. That was a big mistake. I couldn't find any jets to fit it. So after some brain work I decided to make a intake for a Kadron. I overcame all the problems I ran into, like the TPS turned the opposite direction, so I rewired it. The float bowl had a pin hole in it. So I got another on. Jetting was fun. Since it was a 1100 cc engine I started with the jetting for a 2200cc VW, since I was only using one carb. 140 main 50 idle and I forget the size of the venturi. I went up to a 160 main and a 60 idle jet and the bike it sweet now.
helowrench
Re: How do you spell KADRON
Post by helowrench » Thu Jul 11, 2013 10:48 am
Thats awesome.
I have a saying around my house.......
"Nothing is truly fixed until volkswagen parts are on it"
My old Suburban
My sons Volvo
My riding mower.
Filter Pump motor for my pool.
Treadmill.
the list goes on.
I have actually been considering a carb replacement for my riding mower. Rebuild kit for the mower carb is like $60 for everything, just have to overcome my laziness.
doc
Site Admin
Post by doc » Thu Jul 11, 2013 11:38 am
vw experience never leaves you. Many of us learned our mechanics on the original cars. Helo is right on. Got to get something dub on most everything.
Nice build, david!! 8)
doc
Devastator
Post by Devastator » Thu Jul 11, 2013 5:42 pm
Years ago we adapted a 6V VW generator to our Ford 9N tractor because we had a few lying around after converting to 12V. Sold the ford that way too. :D
Neat retrofit!
Devastator's Build Thread
Sandrail
2276 ACVW
MS2Extra EFI W/spark
T3 Turbo making 10 lbs boost
Burning E85
going fast enough."
Mario Andretti
Post by david58 » Fri Jul 12, 2013 6:37 pm
What amazes me is that the bike stock has a advertised rating of 45 MPG. Before the last jet swap it was dead on 33 MPG every time I checked it, but now I am at 43 MPG. Close enough for a monkey with a football headed for the goal line. The point here I am making is that the idle jet does a lot more than just work at idle. If you have a hesitation in a Kad try a bigger idle jet.
