LS2 Wiring and connectors
Moderator: Tom Notch
Re: LS2 Wiring and connectors
Post by Piledriver » Mon Nov 02, 2015 11:26 pm
Those are aftermarket mystery coils. Avoid.
falcor
Post by falcor » Tue Nov 03, 2015 7:19 am
http://thedubshop.goodsie.com/ignition
Buy from a VW guy... I've bought several items from him and I'm superhappy with his services.
kangaboy
Post by kangaboy » Tue Nov 03, 2015 8:58 am
It doesn't look like Mario sells the Truck Coils that I am looking for. I want to find a set of them so I dont have to run a Quad Spark.
Post by Chip Birks » Tue Nov 03, 2015 11:04 am
You don't have to run a quad spark with Mario's ls2 style coils. You do however need a quad spark or similar device if you run his COP setup.
vwi_dduvall
Post by vwi_dduvall » Tue Nov 03, 2015 2:19 pm
kangaboy wrote:It doesn't look like Mario sells the Truck Coils that I am looking for. I want to find a set of them so I dont have to run a Quad Spark.
I am running a set of Mario's LS2 on my 1600 T3 without a Quad Spark Just got it running last weekend and runs just fine. The truck coils just have a lot more kick from what I read.
Could be wrong on that one.
Daniel Du Vall
http://volkswageninsanity.us
"Cause, remember: no matter where you go... there you are"
Buckaroo Banzai Across the 8th Dimension
kangaboy
Post by kangaboy » Tue Nov 03, 2015 2:58 pm
Well, I'm glad you mentioned that. I was under the impression that they had to be truck coils to eliminate the QuadSpark equipment. So will the non-truck LS2 coils work hooked directly to my MS3X?
vwi_dduvall
Post by vwi_dduvall » Tue Nov 03, 2015 5:00 pm
kangaboy wrote:Well, I'm glad you mentioned that. I was under the impression that they had to be truck coils to eliminate the QuadSpark equipment. So will the non-truck LS2 coils work hooked directly to my MS3X?
Thats how I am running it.
Daniel Du Vall
Post by Piledriver » Wed Nov 04, 2015 1:54 am
The quadspark is only needed to drive "dumb" coils, the LS2 coils are all logic controlled.
The MS3X largely exists to drive them.
I have a set of truck coils but have never figured out how to mount them elegantly.
The "normal" LS2 coils just need a few standoffs and bolts.
I'm sure Mario could source you a set of either style LS2 coils.
The IGN1As are also a great choice, many big DI Mercury outboards have them, or their OEM brothers.
They have about the kick of the LS2 truck coils, maybe more.
Redline Weber sells the IGN1As.
I'll see if I can find the Mercury part#... Those are easy to mount, too.
kangaboy
Post by kangaboy » Wed Nov 04, 2015 9:37 am
vwi_dduvall
Post by vwi_dduvall » Wed Nov 04, 2015 7:26 pm
Daniel Du Vall
Post by Piledriver » Thu Nov 05, 2015 3:34 am
Crummy picture, can't be certain from that pic, but probably truck coils based on the thin "ears" for mounting.
Better pics:
http://www.ebay.com/itm/SET-OF-4-GENERA ... Ek&vxp=mtr
Post by Piledriver » Thu Dec 17, 2015 5:15 am
It appears the stacked standoff design can be used on the d585 truck coils just like the std LS2 coils, with a twist:
http://dgreg.phpwebhosting.com/s4/d585_bracket2.jpg
