Mega jolt VR sensor help needed ASAP....
Moderator: Tom Notch
manx3094
Post by manx3094 » Sun Jun 21, 2015 7:14 pm
We are supposed to leave on a 1000 mile trip on Tuesday morning and I believe my VR sensor just went bad. It was purchased from Mario at the dub shop.
Does anybody have a part number so that I can pick one up locally?
Need ASAP....
Thanks,
David
Rob Habets
Re: Mega jolt VR sensor help needed ASAP....
Post by Rob Habets » Sun Jan 03, 2016 1:05 pm
Hi,
did anyone get you a partnumber?
I'm planning to run a dubshop vr-kit on my water/oxy-boxer over here in The Netherlands, so a partnumber would be helpful in case of a sensor failure......
Looks like a Honda part.
Regards, Rob
Post by Piledriver » Sun Jan 03, 2016 1:17 pm
Pictures might help
Ford made a herd of VR sensors for EDIS
It looks like Mario uses the same vr sensor for the hidden and std kit
http://dxkdul4cprxwx.cloudfront.net/dc9 ... 20x820.jpg
Clonebug
Post by Clonebug » Sun Jan 03, 2016 11:03 pm
I'm not really sure how a sensor could go bad unless the clearances were way too tight and it wore half the sensor away.
Mine rubbed just a little bit and never bothered it in the least. We adjusted it a tad bit out and away we went for a tuning session.
It's run for two seasons now without a hitch.
miniman82
Post by miniman82 » Wed Jan 06, 2016 8:56 pm
What's the resistance across it's terminals? I've never seen one go bad, but I guess anything electrical can fail. Need a picture to recommend a part number.
Jadewombat
Post by Jadewombat » Tue Jan 19, 2016 9:02 pm
The sensor can't be mounted too close or too far away from the trigger wheel to pick up the changing polarity of the teeth going by.
