Hall Effect distributor help - minimal connections ?
Moderator: Tom Notch
jhoefer
Re: Hall Effect distributor help - minimal connections ?
Post by jhoefer » Tue Mar 31, 2015 2:53 pm
The distributor base, that L-bracket your spark plugs are mounted in, module ground pin, and battery negative all need to be grounded together.
danielzink
Post by danielzink » Tue Mar 31, 2015 3:15 pm
jhoefer wrote:The distributor base, that L-bracket your spark plugs are mounted in, module ground pin, and battery negative all need to be grounded together.
Yup - I was about halfway there with my ciphering.
Will get everything grounded together within the next day or so and report back.
Thanks.
65 Notch 2300cc Type4
EJ22 powered Rail
http://www.danielzink.com
