knock sensor
Moderator: Tom Notch
dcd
knock sensor
Post by dcd » Fri Dec 19, 2014 2:00 pm
hi im planing to fit knock sensor to my 2276cc turbo engine which going to run with mega squirt 2 the question is where to fit the knock sensor any pic be applicable
jhoefer
Re: knock sensor
Post by jhoefer » Wed Dec 24, 2014 1:09 pm
Most common place I've seen is bolted through the top case webbing near the flywheel: http://www.shoptalkforums.com/viewtopic ... 5#p1047995
That's a type 4, but the location is similar to the type 1. Could even use the open hole just above there.
