Vanagon Digifant - can run with Ignition disconnected?
Moderator: Tom Notch
gearheadgreg
Contact:
Re: Vanagon Digifant - can run with Ignition disconnected?
Post by gearheadgreg » Mon Dec 01, 2014 8:11 pm
Awesome - thanks!
In my distant memory, I thought MS2 had Knock sensing capability built in? Or at least free-ware add-able? Is that a word?
Either way, this looks like a great option for knock sensing with MS.
Parting out Porsches and VWs
http://www.greggearhead.com
MarioVelotta
Contact:
Post by MarioVelotta » Mon Dec 01, 2014 9:04 pm
I have one of those knock modules. My turbo motor was 2 mechanically noisy to get the sensor and module to respond in any coherent manner. I moved the sensor several times. My final location was at the flywheel behind the shroud. But never got a chance to properly test it. I've heard that is a good place though.
Mario@thedubshop.net
2276 Turbo - 92 Octane
11.537 @ 115.74mph - 15psi
1600 S.C. - ?sec @ 10psi (so far) 8)
1600 NA ITB - 18sec :lol:
gearheadgreg
Contact:
Post by gearheadgreg » Mon Dec 01, 2014 11:12 pm
Mario - was that an air cooled with solid lifters, or a wasserboxer with hydraulic? I know not night and day in terms of noise, but maybe, maybe quiet enough.
I Know on some I4 water-cooled VWs, an aluminum bushing in between the knock sensor and block were supposed to quiet some of the frequencies and make it less susceptible to erroneous knock triggers. http://techtonicstuning.com/main/index. ... cts_id=876
I also remember reading an SAE article a million years ago that the torque applied to the sensor had a great effect on the frequencies it picked up on (more torque, higher sensitivity, or vice versa or something like that). Just food for thought.
