LS2 Coil plug wire option I found
Moderator: Tom Notch
aircooledtechguy
Post by aircooledtechguy » Sat Aug 23, 2014 4:37 pm
Maybe this is old news to most of you, but I found that a Bosch Vanagon plug wire set (Bosch P/N: 09-272) works perfectly with the LS2 coils that a lot of us use on our Megasquirt systems. The coil end fits perfectly and uses the same type of connection that the Vanagon distributor caps use and they are a 90 degree fitting. Also the 7mm OD is perfect for standard Beetle air-cooled plug ends (Bosch P/N: 0 356 100 014). Air seals are oddly provided with this set even though it's for water-cooled Vanagons :?: .
Hope this helps. . .
sideshow
Re: LS2 Coil plug wire option I found
Post by sideshow » Sat Aug 30, 2014 11:06 am
I saw those once, they got the from NAPA IIRC...I looked at them any my first guess was last of the ACVW for MX w/FI.
I wonder if it is universal back datable part like pressure plates with the removable collar.
andy198712
Post by andy198712 » Sat Aug 30, 2014 4:06 pm
thats interesting and thanks for listing the part numbers also
Post by Piledriver » Sat Aug 30, 2014 4:33 pm
sideshow wrote:I saw those once, they got the from NAPA IIRC...I looked at them any my first guess was last of the ACVW for MX w/FI.
The Vanagon coil wire, and distributor connection is the ~same as the plugs, little tube with a spring clip to grab the threads.
The whole setup works on a T1/T4 as well (cap/wires) Vanagon/Golf cap is interchangeable on a std body distributor like a 009 or any of the later factory units. Ran it for years on my 914 (w/Vanagon hall distributor) zero problems.
Autozone or OReillys (forget which, maybe both) sells a spiral wound set of wires I'm pretty sure are Magnecor made, cheap. MUCH better than "modern" Bosch wire sets sold for T1s/T4s/WBX
The matching lowZ coil can be used with any properly programmable dwell ignition setup, or even used w/points or a Compufire triggering the Vanagon Golf coil driver---Likely ~best ignition upgrade short of ditching the distributor entirely.
sideshow
Post by sideshow » Sun Aug 31, 2014 10:16 pm
And to keep with the off topicness I run a vanagon rotor in one of my late distributors because it from what I have heard has less resistance or better noise suppression (better at FM band than AM) than the early rotors.
It drops in and hasn't failed in mild CDI use, then again stock rotors have never been a problem w/CDI in my experience.
Max Welton
Post by Max Welton » Mon Sep 15, 2014 9:40 pm
So Nate, how well do the Vanagon wires hold up to the LS2s?
Max
aircooledtechguy
Post by aircooledtechguy » Wed Sep 24, 2014 8:30 am
Max Welton wrote:So Nate, how well do the Vanagon wires hold up to the LS2s?
Max
I've only had mine in operation for about a month or so, so I can't really comment on longevity. I have put about 1500 miles on the car with the new ignition system. The boots at the coil end fit nice and tightly to the LS2 body and no water has intruded in (or salt for that matter). I am pairing them with Denso Iridium plugs and everything looked perfect last weekend when I pulled the #4 plug to check it out.
So far, so good. And no interference with the radio even on AM.
Post by Piledriver » Fri Sep 26, 2014 1:16 am
Don't forget the Milk of Magnesia, I've had my iridium plugs in so long I'm afraid to pull them out...
aircooledtechguy
Post by aircooledtechguy » Fri Oct 03, 2014 8:11 am
Piledriver wrote:I've had my iridium plugs in so long I'm afraid to pull them out...
I had the last set of the same irridium plugs in since going to MS 5 years ago. Other than some slight erosion on the tip of the electrode, they looked great and worked flawlessly. Nothing but iridium plugs for me in my MS powered cars!!
Clonebug
Post by Clonebug » Sun Oct 05, 2014 10:38 am
What's this exotic Iridium stuff you speak of???? :? :?
Post by Piledriver » Sun Oct 05, 2014 1:44 pm
Clonebug wrote:What's this exotic Iridium stuff you speak of???? :? :?
Seriously?
Virtually all late model vehicles come with them from the factory.
They fire hotter than platinums and last ~forever
http://www.sparkplugs.com/learning-cent ... plugs-last
The ones I have IIRC are iridium on the center and platinum pad on the ground electrode.
They don't even cost much more these days.
Clonebug
Post by Clonebug » Sun Oct 05, 2014 3:25 pm
Seriously?
Yes seriously..... :lol:
I haven't installed a plug in any vehicle I've owned except my buggy in the last 20 years.
Post by Piledriver » Sun Oct 05, 2014 4:16 pm
Put a good set of iridiums in it and you may make it another 20 in the buggy...
Newer cars typically have them, so regular plug changes have become a thing of the past.
They hold up, esp compared to ...everything else...particularly well on boosted engines.
Just don't forget a drop of MoM, just so you can pull them back out occasionally for a peek.
Aircooled is also harder on plugs, iridiums seem to shrug it all off.
Also note you can get a 11" Harley twincam plug wire at any HD dealer for ~$4.
Pops right on LS2 coils. (oddly the short wire version of the same app is ~$11)
I shortened them and put some long straight ends on it from a used set of Ford wires, but the Accel bits work fine, just cost actual money--the silicone ends are ~forever.
Only works if you have the coils within 11" of the plugs of course, the Vanagon wires are much longer.
