009 circlip removal???
Moderator: Tom Notch
yodal
Post by yodal » Thu Nov 29, 2012 7:00 pm
Hi, I'm reconditioning my 009 distributor but cant seem to figure out how to remove the circlip thats under the felt pad at the top of the 009 main shaft?
Any suggestions?
I've searched a ton and cant find anything.
Jadewombat
Re: 009 circlip removal???
Post by Jadewombat » Sat Dec 01, 2012 6:45 pm
Attach a picture.
Clonebug
Post by Clonebug » Sun Dec 02, 2012 11:01 am
If I remember correctly I carefully put the distributor housing in a vice to hold it by wrapping it with some cloth to prevent scarring. That allowed me to use both hands with two mini screwdrivers to push on each end of the clip and force it off.
It does take a bit of dexterity..... :wink:
alsoran
Post by alsoran » Mon Apr 01, 2013 10:34 am
Just use a punch set to the pin and give it sharp tap with a hammer. It'll come right apart.
Damn!
Clonebug
Post by Clonebug » Sun May 05, 2013 4:42 pm
alsoran wrote:Just use a punch set to the pin and give it sharp tap with a hammer. It'll come right apart.
Damn!
That removes the shaft but not the advance mechanism.......
ONEBADBUG
Post by ONEBADBUG » Sun May 05, 2013 5:19 pm
Dental picks.
Glenn
Post by Glenn » Tue Dec 17, 2013 6:00 pm
Stick a flat blade screwdriver between the upper and lower shaft and twist. The clip will pop off.
To reinstall, use a 6mm deep socket and a very light hammer to force it back on.
Glenn
74 Beetle Specs | 74 Beetle Restoration | 2180cc Engine
"You may not get what you pay for, but you always pay for what you get"
http://www.DasVolks.com
