Berrien Venture Sand Rail, Street Legal.
Posted: Sun Apr 16, 2017 10:54 am
Street Legal with proper Michigan Assembled Roadster title.
$7999.00
Very well built sandrail. Powdercoated frame, side panels, and engine tin. Custom front ‘wing’ to deflect sand and wind. Race Trim suspension seats. Aluminum front beam. Optima red top battery with custom mounting bracket. Jamar shifter. CNC cutting brake. CNC clutch slave cylinder with CB billet slave cylinder bracket. CNC pedal set with adjustable mount. Morse cable throttle cable. Holley fuel pump and pressure regulator. Aluminum gas tank. Race Trim suspension seats with all weather covers. 5 point G-Force quick release harness. Sunpro tachometer. Quick release steering wheel. Three sets of rear tires; street, desert tracks and paddles all on aluminum rims. Spindle mount front alum rims with motorcycle tires. Full length diamond plate aluminum floor. Rear suspension limiting straps. Alternator. Rear disc brakes, calipers rebuilt last year.
1915cc VW type 1 motor. 120 cam, Scat lite wt. lifters, DPR forged crank, 94 mm cyl., professionally built. Dual Weber 44 IDF carbs. CB thinline deep sump. CB filter pump. Stock doghouse oil cooler. U-bend and stinger exhaust included. Leduc Racing type 1 swing axle trans, close ratio 3rd and 4th. Have build sheet for engine and trans.
I am not willing to sell rims and tires separately.
If you want to see photos of anything in detail or have any questions let me know....
Photos here: https://www.thesamba.com/vw/classifieds ... id=1952238
$7999.00
