Compufire Alternator
Moderator: 2088 bob
TJ530
Post by TJ530 » Tue Nov 22, 2016 3:08 pm
Does anyone have experience good or bad with the Compufire High Output Alternator?
I've read that some of the cheaper High Output versions have problems with bearings and overheating and would like to hear some feedback on them. Thanks.
volksbugly
Re: Compufire Alternator
Post by volksbugly » Tue Nov 22, 2016 5:45 pm
I didn't run that one back in the 90s but I had a custom built high output alternator. The problem with our alternator design is when you get into high 90amp amperages is that the internal parts cant be made the way they need to be, so you end up with 0 output till you reach around 2300 rpms. Atleast that was the problem then... not sure how things are now. :)
TJ530
Post by TJ530 » Wed Nov 23, 2016 11:28 am
volksbugly wrote:I didn't run that one back in the 90s but I had a custom built high output alternator. The problem with our alternator design is when you get into high 90amp amperages is that the internal parts cant be made the way they need to be, so you end up with 0 output till you reach around 2300 rpms. Atleast that was the problem then... not sure how things are now. :)
The electrical shop I had asked that does all our motor rewinds for work looked at me funny when I asked if they could rewind my Alternator. It seems like not many people run higher Output Alternators which is suprising seeing how affordable programmable fuel injection has become.
volksbugly
Post by volksbugly » Wed Nov 23, 2016 12:39 pm
You don't need a high output alternator for EFI, I've run the 55amp and 75amp with full sequential without problems.
volksbugly
Post by volksbugly » Wed Nov 23, 2016 12:40 pm
You don't need a high output alternator for EFI, I've run the 55amp and 75amp with full sequential without problems. You really only need it if your running 12 high beam flood lights or a killer sound system.
TJ530
Post by TJ530 » Wed Nov 23, 2016 12:43 pm
volksbugly wrote:You don't need a high output alternator for EFI, I've run the 55amp and 75amp with full sequential without problems. You really only need it if your running 12 high beam flood lights or a killer sound system.
Got a link to the 75amp one? I had thought anything over 55amps was considered High Output.
volksbugly
Post by volksbugly » Wed Nov 23, 2016 12:46 pm
I got it at my local shop. It is a Bosch one.
